Gen 2 Throttle Body: Safety of manual movement during cleaning?
Discussion in 'Gen 2 Prius Main Forum' started by Felix1414, Apr 7, 2026 at 11:12 PM.
  1. Felix1414
    Felix1414 New Member
    24
    Cambodia
    Hi everyone,
    I am currently maintaining a 2004 Prius (Gen 2) in Phnom Penh, Cambodia. Recently, I’ve noticed some jerking/hesitation when the engine starts, particularly during low SOC (44%) and high battery temperatures (39°C+).
    I recently fixed a P0446 code by replacing the EVAP VSV (Vacuum Switching Valve), which resolved that specific issue. Now, I want to focus on the intake side. My recent Car Scanner data shows:
    • Absolute TP: 18.82% (at 1199 RPM charging state)
    • Relative TP: 4.71%
    • LTFT: 3.91% (improved from 7.03% recently)
    I am planning to clean the throttle body this weekend to address the carbon buildup. However, I’ve seen conflicting information regarding the electronic throttle body (ETB):
    1. Is it safe to manually push the butterfly valve open while the car is OFF? Some say it risks damaging the internal plastic gears or the TPS calibration.
    2. Is the "IG-ON + Accelerator Pedal to the floor" method the only "safe" way to have the motor open the valve for cleaning?
    3. In a dusty environment like mine, is there a significant risk of solvent seeping into the motor housing if I don't remove the entire assembly from the car?
    I would appreciate any insights from those who have performed this maintenance on a high-mileage Gen 2. Thank you.
  2. ChapmanF
    18,570
    That's all I've ever done, without worrying about it. Now I'll probably worry next time. See what you've done?
    It may come down to this: make sure the car is OFF for sure. When powered, the motor will resist you and try to maintain the throttle position; in those conditions, you might apply enough force to skip or break gear teeth.
    Then, with the car definitely off, apply just gentle force to the butterfly. Moving it slowly is good enough. Applying more force to move it more quickly would have a greater risk of skipping or damaging gears.
    Pay attention to whether it feels like it is moving easily and smoothly. If it feels at all as if you would have to force it, perhaps reconsider.
    There is one kind of gear train that notoriously doesn't cooperate when you try to 'drive' it from the 'driven' end: that's a worm gear train, where the electric motor spins a long spiral-threaded 'worm' against the side of a conventional gear. I don't think that type of gear train is used here. You can often tell pretty easily just by looking at the shape of the motor/gear assembly, which for a worm drive will look like the motor axis is perpendicular to the driven-gear axis and lying tangent to the gear. If the assembly has that sort of look, don't count on being able to move the butterfly by hand.
    But I think the shape will suggest more of a conventional gear train with the motor axis parallel to the butterfly shaft. In that case I don't foresee trouble gently moving the butterfly.
    I am not, however, offering to buy you a throttle body if I'm wrong.
    Is that even a way of doing that? I'm not sure I've ever heard that would have that effect.
    I don't have even the beginnings of speculation on that one ....
  3. rjparker
    10,558
    6,623
    I always did my gen2s manually. Gasoline is a solvent as well. Use specific throttle body cleaner and don't drop your brush inside the manifold.
  4. Felix1414
    24
    Cambodia
    Yes, that's also the point I'm confused about. In all the videos I've seen, all the maintenance technicians manually open the throttle valve, but the written materials tell me that the throttle valve of the second-generation Prius is electronically controlled. As long as the engine is not started when powered on (that is, pressing the start button twice but not stepping on the brake to prevent the car from entering the Ready state), the throttle valve will be fully opened. If it's done manually, it may cause gear damage, which is also my confusion. In actual operation, everyone does it manually, so I'll try it myself. Slowly turn it by hand. If there is resistance and it can't be opened, then try the method of powering on and stepping on the throttle again
  5. Felix1414
    24
    Cambodia
    So in fact, it is also possible to clean with gasoline, right? Will gasoline have any other impact on the components inside the throttle valve?
  6. rjparker
    10,558
    6,623
    No don't use gasoline. Buy a spray can of throttle body cleaner, a can of maf cleaner and some small brushes. Those cans are safer for everything including you. They will last many years.
    If the throttle body opens with ignition on, it would be easier. Easier is good. Don't run the battery down by leaving the ignition on for a long time especially if the 12v battery is old.
    Don't use a brush on the maf. Its expensive and the aftermarket versions are junk.
    #6 rjparker, Apr 8, 2026 at 7:09 AM
