How much is your local "Trump at the Pump Tax?"
Discussion in 'Fred's House of Pancakes' started by Georgina Rudkus, Mar 26, 2026.
  1. ETC(SS)
    7,367
    Probably it did not occur to you.
    GB - the site, is just the data.
  2. ChapmanF
    18,585
    o_O?
    I hadn't visited gasbuddy.com in a while, but I went there just now, clicked Gas Tools at the top, clicked Gas Price Map, and immediately saw the same type of map Bob posted. That didn't take long.
    As far as it being "just the data"—well, that's pretty much what I believe it is, visualized here as colors on a map.
    Can you clarify what you mean by 'propaganda'?
  3. bwilson4web
    16,383
    My understanding is Gas Buddy uses member reports so the resolution is down to cited stations and fairly current.
  4. ChapmanF
    18,585
    That's definitely the way it worked back when I was a member actively contributing member reports. Haven't heavily used it for some years now (before my first Prius, the vehicle I was driving provided about triple the incentive to check gasbuddy for fillups). As far as I know, it still works about the same way.
  5. ETC(SS)
    7,367
    I'm notionally required to use GB on the job to try and find the lowest price.
    Do I?
    Nope.
    However (comma!!!!) I'm an "actual user."
    Does that mean that I know more about it than others?
    Nope.
    Gas price data is gathered through crowdsourcing for the most part - and that all means what it means.
    It's numbers.
    From Crowds.
    THEY are always truthful.......riiiight? ;)
  6. Mr.Vanvandenburg
    1,358
    596
    2020 Prius Prime
    My Costco hasn’t gone down from when he threatened obliteration of Iran, which means nukes if he was truthful. I watch Gasbuddy to check, shows the last data, and I don’t need to make up stuff about the reporters are lying. Making up stuff and casting doubt is such an easy ploy. That’s why he uses it on elections he doesn’t like. Gasbuddy works ok for me although I use next to no gas.
  7. ETC(SS)
    7,367
    The highest average gas prices in the 2020s occurred in June 2022, when the U.S. national average briefly topped $5 per gallon following Russia's escalation of their already 8-year-old war in Ukraine.
    A WAR THAT WAS ESCALATED by our flaccidity in the middle east, and some unfortunate statements by a reckless regime that ACTUALLY stated that if the Russians only invaded "a little bit" it would not be that bad....which in the world of international politics is like saying that:
    "It's not really rape, it you just stick the tip in."
    Of course......it's not as cosmicaly shortsighted as drawing a red line that you later rub out and deny any knowledge about......but hey......
    I get WHY history is NOT everybody's friend.
    You can't obfuscate that with gas buddy, Whopper Wednesdays, or by pretending that the IRGC isn't 'really all that bad.'
    Gas prices WILL GO UP MORE, probably and it will probably be a net benefit for the Dems.
    And?
    Life will go on.
    See you at the polls! :)
  8. ChapmanF
    18,585
    I'm still not sure I understand what you intended with your choice of word "propaganda-graph" in #59.
    The first time I asked, you seemed to be making a distinction where "GB - the site, is just the data" and what you meant by "propaganda-graph" I guess just applied to showing the data on a map, like the one Bob shared.
    But after I pointed out that "GB - the site" in fact supplied the graph—by feeding the data into software to make a map display—it seems now like you are re-anchoring your "propaganda" call in the "just the data" part now.
    Because GB uses crowdsourcing to get the data? And therefore to report the crowdsourced data is somehow to propagandize? Because maybe all the individual members supplying data points could be acting in some coordinated fashion to cause the aggregate reporting to be propaganda?
    Whose propaganda do you suppose it to be? What political interest is being preferentially advanced by the display of current gas prices on a colored US map? And by what means do you suspect that the gasbuddy members individually supplying that data may have been induced to falsify their reports to advance that interest?
  9. ETC(SS)
    7,367
    Gas Buddy is just data.
    -a noun.
    Propaganda what you do with the data.
    -a verb.
    Bob and I spar frequently but could probably spend a friendly meal together bantering and ribbing each other about many things - including the fact that his Marilyn Land shirt is starting to pearl up a bit and that I might like to buy a suitable replacement..... :ROFLMAO:
    If you're genuinely offended by my correct contextually accurate use of the word "propagando-graph" then I offer an equally genuine apology.....FOR THAT ONE POST.
    However (comma!) I'm going to continue to call balls and strikes as I see them, and the "block user" feature DOES work.... :cool:
