Do I need these services?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Godawgs, Apr 7, 2026.
  1. Godawgs
    Godawgs Junior Member
    Portland
    2018 Prius Prime
    I have a 2012 Prius with 115,000 miles. We drive about 6,000 miles per year with no plans to trade it in. When last in for service the garage recommended the following:
    Spark Plug Replacement $301
    Brake Flush $179
    Fuel Injection Service $259
    Transmission Flush $264
    Coolant Flush $235
    Inverter Coolant $199
    I had the Coolant fluish, brake flush, and inverter coolant all done at 61,000 miles on May 2017, but never the other services.
    What should I have done?
    Thanks for any advice!
  2. ColoradoBoo
    ColoradoBoo Senior Member
    1,285
    893
    Monument, Colorado USA
    All except the Fuel Injection Service....just make sure you fill up your tank with "Top Tier" gasoline and that'll keep them cleaned out for you.
    I would ask about the cost of the spark plug replacement....sounds more like a $150-200 job than $301...I'd remind them it's a 4-cylinder and easy peasy!!
    BTW, that's an excellent price for the transmission service....last I checked, my dealer charges $310 for it.
  3. Mendel Leisk
    41,995
    I won't comment on the timing, but just considering each item:
    Brake Flush $179 <Toyota USA says nothing regarding brake fluid change (presumably what they're actually doing), but Toyota Canada recommends tri-yearly or 48k kms, whichever comes first
    Fuel Injection Service $259 <Pure waste of money
    Transmission Flush $264 <Toyota USA (and Canada) say nothing regarding transasxle fluid change (presumably what they're actually doing). That said, I would do at least one. Still, that price is ridiculous, even in Canadian dollars it's ridiculous. A trasnsaxle fluid change is no more complex than an oil change, and considering there's no oil filter, the difference in supplies is trivial. I wouldn't pay over $100 USD. Make sure they're using Toyota ATF WS, from freshly opended bottles.
    Coolant Flush $235 <Presumably engine coolant change. That's about the usual full-retail price I guess. See the attached schedule to determine if it's warranted.
    Inverter Coolant $199 <Per previous comment. Heady thought: how about $200 even
    Attached is a summary of the Toyota USA maintenance schedule, extrapolated to 240k miles and 24 years.
  4. BiomedO1
    4,295
    2,255
    Left Coast
    IMHO:
    Spark Plug Replacement $301; Due for replacement
    Brake Flush $179; No official Toyota recommendations, but other OEM specify 3-5 years. It's pretty humid in Portland. There is a couple of test you can run.
    Fuel Injection Service $259; Hard Pass - buy some over the counter injector cleaner and dump it in on your next fill-up.
    Transmission Flush $264, No official Toyota recommendations, but after 14 years and 115K miles, you should probably change it.
    Coolant Flush $235
    Inverter Coolant $199; Both coolants should probably be changed, You've reached the 10 year time interval but not the mileage interval - chemicals and oils breaks-down and get contaminated over time. If you look at the footnotes of your manual, after the first coolant change; it reverts to 50K mile intervals.
    I also have an issue with terminology - a change vs a system flush are very different procedures. One will require at least 2.5x more fluids to accomplish. I know some people don't see a difference, but billing for a flush when they are actually doing a change is, technically FRAUD. The OEM manual ONLY ask that the fluids be CHANGED; doesn't state "flush" in the documentation. Service writers will always try to sell you the expensive option; unless you correct them. That's been my experience.
    Here's a web site to get a rough price comparison. I'd ask for a service discount; if they are going to do multiple services in one visit - They're not going away and coming back, so that's saving them time and money; which should reduce your cost. Toyota Prius Spark Plug Replacement Costs
    #4 BiomedO1, Apr 7, 2026
    Brian1954 likes this.
  5. Godawgs
    Portland
    2018 Prius Prime
    Appreciate the replies thus far. These were dealer prices so I may get a quote from an independent shop.
    BiomedO1 and ColoradoBoo like this.
  6. ColoradoBoo
    1,285
    893
    One additional comment, some places like to do "flushes" instead of a drain and fill. Save your money, request drain and fill....transmission and coolant doesn't need flushing and, if done wrong, can actually create problems.
    BiomedO1 likes this.
  7. Mendel Leisk
    41,995
    A lot times the dealerships say flush, when in fact it's a drain and fill. Virtually always.
    @Godawgs the elephant in the room: it's your car. Study the schedule (table format I posted early in infinitely easier than trying to make sense of the event-by-event format in Toyota USA's Warranty and Maintenance Booklet), make a decision as to what you're hiring them to do, get a quote.
    ColoradoBoo likes this.
  8. cdherman
    cdherman Member
    59
    25
    Kansas City
    Drain and fill , versus flush:
    If nothing has gone wrong and the system is functioning a drain and fill is THE way to go. There are power flush systems that force new fluid into the vehicle. Maybe a good idea if some part has exploded and you want to clean things out. But the flush systems can stir up debris and make things worse too....
    Drain and fill is best if you are OK and just want to replenish the additives in the fluids. Not a bad goal. If you have old, but decent fluids, draining say 70% of the fluids and then replacing is just fine. Gets you new additives. MUST use genuine Toyo stuff.
  9. CR94
    CR94 Senior Member
    2,763
    1,210
    Northwestern S.C.
    Most of those don't even to be done yet---especially the ones that were already done only 54,000 miles ago.
  10. Mendel Leisk
    41,995
    Drain and fill versus flush discussion is a moot point? The debate as to which is preferred is predicated on the assumption the service writer knew the difference. They’re VERY likely are just using the word flush erroneously, and it IS drain and fill they’ll be doing.
  11. BiomedO1
    4,295
    2,255
    Left Coast
    The service writer's job is to be the liaison between the dealer technician and customer - take care of the paperwork, phone calls, get additional repair work authorizations, and explain things to the customer. Lets face it; some really good technicians don't have very good interpersonal skills or are good at paperwork. IMHO - service writers SHOULD know the difference between a change and flush; so they don't get the dealership sued for false statement or worse; putting things in writing that wasn't done.
    Just my two cents...
  12. Mendel Leisk
    41,995
    @NutzAboutBolts, both of them IIRC, worked at Toyota dealerships, and I've heard them use the term flush in place of drain-and-fill. Language is what it is, misnomers crop up, become entrenched. Google where did sideburns come from, bit of a rabbit hole.
  13. BiomedO1
    4,295
    2,255
    Left Coast
    It might just be me; because English isn't my first language. IMHO; playing fast and loose with the written word - DOESN'T make reading and understanding technical manuals any easier. :(:sleep::whistle: Maybe it's not really genZ's fault???o_O I am a visual learner, but I can usually spot errors and BS a mile away. Unfortunately, someone with less experience can't or won't.
  14. Mendel Leisk
    41,995
    Still, the OP's dilemma is the need for, and expense of, various services. Service writer VERY likely used flush when they're going to do drain-and-fill. He could clarify that with a phone call.
    My 2 cents: everything there is overpriced, and their pushing the fuel system service (never mentioned by toyota) is telling.
    CR94 likes this.
  15. CR94
    CR94 Senior Member
    2,763
    1,210
    Northwestern S.C.
    From General Burnside, of course, and I knew that long before Google existed.
  16. Mendel Leisk
    41,995
    It went through a few convolutions in it’s evolution; from the google AI summary:
    The Linguistic Shift: Over time, "Burnside whiskers" became shortened to "burnsides," and later, likely due to a linguistic phenomenon known as metathesis (reversal of syllables), it became "sideburns"
    CR94 likes this.
  17. Godawgs
    Portland
    2018 Prius Prime
    I went to an independent shop that I have used before and asked for drain and fill on all. They quoted me:
    Spark Plug Replacement $433 (!!) I did watch a video on this and it is quite convoluted, in my opinion
    Brake Flush $140
    Transmission Flush $252
    Coolant Flush / Inverter Coolant $365
    Except for the plug replacement there are slight savings with the independent but not nearly as much as I expected.
  18. BiomedO1
    4,295
    2,255
    Left Coast
    I would probably get everything except the spark plug replacement done at the independent shop. I prefer to support local community small businesses, rather than corporations. That's just me.
    Make sure they're just drain and fill the coolants - a high pressure flush system can damage your cooling system, if it isn't set-up properly and pressures aren't managed properly.
    I've seen iridium spark plugs go more than 175K miles, though your mpg will start "tanking", because of weak spark. Get that job done at the dealership or mobile mechanic, I've linked above. Also ask that shop to double-check that spark plug replacement estimate; it seems to be a bit out of the ball park. Show them your dealership estimates and that app link, because repair shops are usually very competitive and I can't think of any reason why they are so far off on that spark plug replacement.
    Good Luck....
  19. Mendel Leisk
    41,995
    Again with the "flush" terminology, ah well, guess it's an industry-wide misnomer. Spark plug replacement takes about an hour, maybe hour and a half (due to to sand-pounding amount of wrenching required, just to get to the damn plugs), for a pro, and the plugs were $66 CDN in my experience:
    (I usually get plugs from a dependable local auto specialty store, but dealership was cheaper in this instance)
    The brake fluid "replacement" is reasonable. Hopefully they can manage it, the Toyota Prius system is tricky.
    Transaxle fluid change is comparable to oil change in complexity, just a little different. Last time I checked (within the last year) my nearby dealership was selling liters of Toyota ATF WS for around $11 CDN apiece. Four are needed. Anything over say $125 they're taking advantage. You want to be VERY sure they're not subing another fluid. Toyota has a strong caution in the Owner's Manual, that anything else may damage the transaxle. There's also the drain/fill bolt washers should be changed, about $4 USD max for the pair.
    The last item I'd assume to be engine and inverter coolant replacement, and for both not too far out of line. Hopefully they're experienced with 3rd gen Prius, and use the Toyota Super Long Life. Toyota isn't adamant you use their coolant, but it's a safe bet.
    Any chance of DIY? :whistle:
    #19 Mendel Leisk, Apr 9, 2026
