Doublechecking the fluid types.
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by roguetadhg, Apr 10, 2026.
  1. roguetadhg
    roguetadhg Junior Member
    24
    2023 Prius
    Limited AWD-e
    I've been on the hunt of making sure the fluids are taking care of. I have a 23 eAWD. Am I missing any of them?
    - Oil
    - Coolant (Engine)
    - Coolant (Inverter)
    - Transmission
    - Transaxle
    - Rear Transaxle ( eAWD)
    - Brake
  2. ETC(SS)
    7,426
    Blinker?
    (In case your car is "dealer serviced')
    Tande and roguetadhg like this.
  3. Mendel Leisk
    42,150
    Sounds complete. Apart from the relatively trivial windshield washer fluid.
  4. Hammersmith
    Hammersmith Senior Member
    2,417
    2,471
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Cross off transmission. The Prius only has the transaxle(s).
    So:
    Oil - 0W-16 - 4.4qt - I prefer Valvoline Restore & Protect(VRP) or Toyota Genuine Motor Oil(TGMO)
    Oil filter - 90915-YZZN1
    Oil drain plug gasket - 90430-12031
    6m/5k miles
    Engine coolant - Toyota Super Long Life(pink) - 00272-SLLC2 - 6.4qt
    Inverter coolant - Toyota Super Long Life(pink) - 00272-SLLC2 - 1.7qt
    need two jugs(plus maybe a tiny bit of water if needed(<0.1qt) - do the inverter first)
    5y/50k miles
    Front transaxle - Toyota TE Fluid - 08886-81986 - 3.9qt
    Rear transaxle - Toyota TE Fluid - 08886-81986 - 1.5qt
    Transaxle drain plug gasket - 90430-18008
    need two jugs(you'll have a lot left over - don't save it) and four gaskets
    6y/60k miles(could go a bit longer)
    Brake fluid - DOT 3 or DOT 4 - I prefer DOT 3 unless lots of hard/constant braking; brand doesn't much matter - need around 2 pints, but maybe have a third on hand just in case
    as needed - change when moisture hits no more than 3%(I prefer changing when hitting 2%) <2% good / 2-3% borderline / >3% replace immediately
    Other stuff
    Air filters:
    Engine - 17801-F2060 - as needed
    Cabin(standard) - 87139-YZZ83 - as needed
    Cabin(premium) - 87139-76020 - contains activated charcoal to reduce odors - change yearly
    Battery intake - G92DH-47110 - as needed
    Spark Plugs - 90919-01289 - 120k miles
    Wiper Insert, Driver - 85214-08050
    Wiper Insert, Pass - 85214-0E130
    as needed - I do twice a year, but my winters are hard on them
