bad clunking sound when ICE turns on under low to moderate acceleration
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by JellyDoughnut, Apr 8, 2026 at 12:16 PM.
  1. JellyDoughnut
    JellyDoughnut New Member
    Wednesday
    Seattle
    Hey everyone,
    I've owned my prius for about 5-6 years now and haven't really had a single problem with it until now. Under low to moderate acceleration it makes a sort of repetitive clunking sound and can feel the clunk as well. It goes away in high rpm and electric only.
    I headed to the forums and google and everything pointed towards EGR, so I took that whole thing apart, cleaned everything like all the videos showed. Got the cooler, pipe, valve, and intake all cleaned up but they weren't really that bad like all the videos showed. I could still blow through them perfectly fine. Replaced the PCV valve recently as well. Didn't change at all.
    So now I'm leaning towards a transmission problem, maybe just low on fluid? or the damper plate between the engine and transmission. Any ideas on what else it could be? Or anyway to inspect those parts to see if it's the problem? I heard there may be an inspection port for the damper plate?
    The only code it's throwing, is the P2195 which has been on and off for th entire time I've owned it. Replaced the o2 sensor and didn't really change anything.
    Any help would be appreciated.
  2. BiomedO1
    4,212
    2,198
    SacTown, Ca
    I'm not surprised; don't know how a "clunk" can be caused by your EGR? That would have more to do with your P2195 code, though that would also be a stretch.
    Low ATF shouldn't cause that either, if it did - your transmission isn't long for this world and it would be doing that in EV mode too. IMHO; ATF should be changed every 100K miles anyways. It's probably black as tar by now.
    My money would be on the damper plate, motor mount, or a misdiagnosed CV axle joint; based on the description above. You can remove your bell housing inspection plate to look for debris, bits and pieces of the damping springs.
    Good Luck....
  3. CR94
    CR94 Senior Member
    2,759
    1,209
    Northwestern S.C.
    Mileage?
    Is the "clunking" worse during turns?
  4. JellyDoughnut
    Wednesday
    Seattle
    Cars at 240k miles. engine was replaced around 190k with another lower mileage motor.
    No clunk doesn't get better or worse during turns
    CR94 likes this.
  5. Mendel Leisk
    41,946
    Second “mileage?”
    Engine coolant level stable in the reservoir?
  6. rjparker
    10,575
    6,633
    That is an unfortunate side effect of egr mania in certain forums. Sorry about that, I know it was a lot of work for nothing.
    However it sounds a lot like a head gasket in your second "lower mile" engine.
    If it was a blown damper high rpms would be worse. If it was a cv joint it would click in turns but you won't feel it. Both of these possibilities are very rare on a Prius.
    If the used engine has blue injectors and a model plate with X2ZR-W25, it is US salvage and very prone to hg leaks.
    Borescope testing on a manually pressurized cold engine full of coolant can be definitive.
    #6 rjparker, Apr 10, 2026 at 2:02 AM
    BiomedO1 likes this.
  7. BiomedO1
    4,212
    2,198
    SacTown, Ca
    I guess a misfire could be described as a "clunk". I guess it's time to get a bunch of knowledgeable friends together and take a poll o_O or have someone who knows what they are doing look at it. We only have what the OP has typed, since we can't hear, smell, or see what's going on.
    Good call RJ.... That's a well know defect on a gen3 motor and a used replacement is a gamble that got you 50K additional miles down the road. I always tell people to go with an updated rebuilt motor, because a used motor has a large sunk cost and is a gamble with known failure points. There's no proof that was a low mileage replacement motor, Just the word of the guy that sold it to you. Even if it's true, that it's a low mileage engine - it has known and proven defects. If you can do the swap yourself, you can cut the cost in half, just know that you may have to do it again, in the near future.
    So you've only put about 50K miles on that car in 5-6 years???
    #7 BiomedO1, Apr 10, 2026 at 11:07 AM
