I inherited a 2010 Prius with 90K miles and it is now the daily driver. I gave away the Integra, so it is now my only car and I am motivated to prevent disasters / issues. As I understand it, the EGR buildup is similar to arteriosclerosis and will seriously damage the engine (overheating). Is there a simple non-invasive diagnostic to determine if a cleaning is needed? If one was open up the system to visually inspect, wouldn't it be silly not to clean it? Or is cleaning a significant undertaking? I am trying to get a sense of time / tools / cost to DIY and when I need to do this. Again, the Prius is 90K miles and 15 years old. Google indicates: "Cleaning the Gen 3 Prius EGR system involves removing the EGR cooler, valve, and pipe, soaking them in powerful cleaners (like brake cleaner, oven cleaner, or fuel system cleaner), scrubbing passages with brushes, rinsing thoroughly (hot water/air compressor helps), and cleaning the intake manifold's EGR ports, swapping parts for a clean set to minimize downtime, and reassembling with new gaskets to prevent clogging and head gasket issues." I am wondering if it is sensible to replace the EGR system parts (EGR cooler, valve, and pipe). So as to minimize downtown and ensure a proper clean at year 15+. I don't have a second car and would like to avoid renting a car.
Take a look here. Basically you need a decent OBD reader and look at EGR airflow. 21-22 kPa is a value for a cleaned EGR. But it won't tell you the whole story because it measures total airflow. Unfortunately in intake manifold are 4 small holes and they clog different so next step is to dismantle intake manifold and take a look at those holes. Those are two steps which doesn't involve too much work
Assuming it's never been done previously, the 90k miles would be motivation enough for me. It can be done in a weekend. Prior to starting I would make sure you've got all the tools needed, and a decent idea of what's involved. There's strategies that'll make it easier: 1. If you're not planning on a full coolant drain and fill, consider just draining a couple of quarts (from the radiator drain spigot) into a clean container, and when done just pour it back into the reservoir. This'll reduce coolant spill to near-zero, and no hose clamping/plugging needed. 2. Remove the cooler lower bracket nut and stud, any convenient time in advance, and leave it off. Also, remove the cooler top bracket bolt, and the the nut and stud going through the valve into block. Lube both and reinstall. This'll make the eventual removal of the valve/cooler combo go much smoother, and negate the need to remove the studs at the rear cooler connection, to exhaust manifold. This in turn will help to retain the gasket there, and to align it during reinstall. 3. Get the cooler soaking with cleaner first, and check on it hourly, rinsing-and-repeat till clean. Forget about brake cleaner or similar solvents for this. Either soak with concentrated (water) solution with Oxi-Clean, or for more expedience, either Sodium Hydroxide (NaOH, aka "lye") or Potassium Hydroxide (KOH, aka "caustic potash"). The latter is still readily available, commonly used in soap making. Use appropriate caution with the latter two, they're strongly caustic. 5. See top two links in my signature (on a phone turn it landscape to see signatures). Also, this workflow may help.
Burebista's suggestions are good. See also Techstream EGR Valve Blockage Data | Page 3 | PriusChat Cleaning out the EGR ports of the intake manifold is far less work than cleaning out the cooler, and more likely to be needed at only 90k miles if the engine isn't guzzling a lot of oil.
should “isn’t” be “is”? that aside, I think you’re saying an engine burning oil is more prone to carbon buildup in the EGR passages? that may well be, but even without oil burning I’d stick to 50k miles max cleaning intervals, for optimum EGR operation.
Yes, to your second question. Have we seen any cases of an engine that isn't guzzling much oil clogging the EGR cooler as early as 90k miles? Mine showed minimal restriction at nearly 160k in the "mode 6" automated test for EGR clogging.
My grand daughter's 2013 EGR cooler was totally plugged (at least visually) at 190k miles and never threw any EGR related codes. I suspect that the EGR codes are related to the EGR valve function and don't directly relate to flow through the cooler but that is an uneducated guess. In my case Purple Power worked best for cleaning the cooler but it does take time and several rinse and repeat steps as others have mentioned.
This link has been given a couple times in this thread, but won't hurt to give it again: Techstream EGR Valve Blockage Data | Page 3 | PriusChat It describes how to pull up the results of the car's most recent self-test of EGR flow. This value (in pressure units, because of the way the test is done) tends to be around 21 or 22 kPa with a new or freshly-cleaned system, and lower numbers indicate some degree of flow reduction. (So, clogging can make the numbers lower, and so can a rutted ski-jump inside the valve actuator, as other threads here describe.) The test result is the trigger for the P0401 code, but the trigger point is a very low value, like less than 1 kPa. That's a long way from the 21 or 22 of a clean system. I did the job on mine when I saw it was down to 10 point something, rather than waiting for it to get low enough to trigger the code.
Yeah I would just go by miles. While oil-burning may accelerate carbon accumulation, I don't think it's the sole cause: exhaust is inherently sooty. Also, the data supplied by the car seems like a sleepy sentry: and it only monitors total flow, does not detect flow variations in the individual EGR tributaries of the intake manifold, which are prone to unbalanced clogging. I've read too, that even a light carbon coating in the cooler, while it may not impact flow that much, will impede the ability inherent in it's namesake: cooling.
Yes, and that's why I cleared out the EGR passages of the intake manifold before reading the car's self-test results the first time. #1 looked partially (~½ of its area?) blocked, but the others scarcely at all.
