200,000 Mile Club
Discussion in 'Gen 3 Prius Main Forum' started by Raytheeagle, Apr 10, 2019.
  1. Prius DIY nut
    Prius DIY nut Member
    92
    43
    Ontario, Canada
    I just crossed 300k km on my 2012 Prius which is close to 200k miles. I got it used with 160k km on odometer.
    1) Did you replace the HV battery pack? - No. Do you maintain it? - Cleaned the battery cooling fan (was not dirty) at 240k and installed homemade air intake filter.
    2) Did you replace the 12v battery? - Yes, at 250k, but as a preventive maintenance, old battery still tested as good.
    3) Did you replace the transaxle fluid? How often? -- Yes at ~240k only once, but will do more often going forward.
    4) Did you replace the brake pads? - Yes. Rear sliding pins got stuck due to winter road salt and caused excessive pads wear. Serviced with some new sliding pins, and new pads and rotors in the rear and front.
    5) Your lifetime MPG (if available)? - Not known. Currently at 4.3-4.5l/100km or 52.3 to 54.7 mpg depending on driving mood.
    6) How often do you change your oil? - Every 5000km or less. Does your Prius consume oil? - No, or maybe a little as I cannot really notice between the oil changes. What brand / product did you use? - Used to use Mobil 1, then just Mobil, full synthetic.
    7) How about posting a picture of 200,000 miles on ODO? - Yes, here: PXL_20251029_224336225.jpg
    8) Did you install an oil catch can? How often do you inspect or dump it? - Yes, after EGR circuit cleaning at 240k km. Approx after each 1000km and more often during winter. I have installed a drain valve to avoid opening it as it is located under the engine. Do not inspect it, only drain.
    9) Have you cleaned the egr circuit? How frequently? - Yes, just once, but will do it again if I see a carbon buildup in the air intake.
    10) Any other maintenance? - Rust protection undercoating every year for the last three years. Replaced part of surface corroded, but still working braking lines in the rear. Changed engine coolant pump and thermostat as a preventive maintenance, rear wheel hubs (NSK brand) after the left rear speed sensor failed and then both front wheel hubs as a preventive maintenance at 290k km. Plan on replacing rear trailing arm bushings and front control arms, sway bar bushings and ties next summer as a preventive maintenance, but currently no issues/noises with old ones yet, just for peace of mind.
    #201 Prius DIY nut, Nov 26, 2025
  2. GustoGuy
    GustoGuy Member
    61
    I bought a 1 gallon container of Fluid film and I sprayed the inside of my wife's 2013 Ford Escape rocker panals and this summer I am going to put my Prius up on Jack Stands and spray the inside of all the frame rails and inside the rocker panels. I bought some Cinnamon essential oil and mixed a small amount in the 1 gallon container of Fluid Film so my vehicles won't smell like a sheeps ball sac.
  3. Mendel Leisk
    41,948
    I think the whole sheep smells thus, not just that bit you mentioned.
    johnHRP and GustoGuy like this.
  4. GustoGuy
    GustoGuy Member
    61
    Cinnamon essential oil really helps to get rid of the sheep smell. . My wife never complained about any smell. When I first opened the can of Fluid Film it definitely smelled like sheep sebum
  5. Mendel Leisk
    41,948
    I’ve used boiled linseed oil, just brushed-on external suspension components, bolts, anywhere I’ve noticed corrosion starting. Seems quite effective, and lasts.
    Merkey and GustoGuy like this.
  6. rjparker
    10,580
    6,636
    Eric O has several Fluid Film videos and uses it on his own Tundra. He is not sponsored.
  7. Mendel Leisk
    41,948
    Love his baaing sound effect!
  8. GustoGuy
    GustoGuy Member
    61
    Damm right. LOL. Minnesota road salt eats up cars and trucks. My Prius is darn near rust free because I have used Fluid film as well as Amsoil MP (Metal protector) as an undercoating and I sprayed it into body panels and into frame rails. I just had Andrew from Minnesota Hybrids replace my HV battery today. Only $850 dollars which is no worse than the cost of a new set of 4 tires versus considering having to junk my car since it would cost $3500-$4000 if a dealer were to do it. I am now going for 500,000+ miles or 804,672 Kilometers for our Canadian friends and there is a good chance that my car will make it.
    #208 GustoGuy, Jan 13, 2026
  9. Dodge Propshaft
    Dodge Propshaft Junior Member
    Wisconsin
    Just crossed 200K today after purchasing it last year at 160K - we're putting about 700 miles on a week at the moment.
    1) Did you replace the HV battery pack? No. Do you maintain it? No.
    2) Did you replace the 12v battery? Yes.
    3) Did you replace the transaxle fluid? How often? Yes, replaced at 191K.
    4) Did you replace the brake pads? No.
    5) Your lifetime MPG (if available)? Not Available - Getting 37 - 43 MPG depending on weather.
    6) How often do you change your oil? 5000mi Does your Prius consume oil? No. What brand / product did you use? Mobil 1, Kirklands or whatever 0W20 full synthetic is on sale.
    8) Did you install an oil catch can? No.
    9) Have you cleaned the egr circuit? No.
    New Aisin Water Pump, Shocks & Struts at 195K
    Replaced head unit with Pioneer DMH-W3000NEX
    Replaced headlight assemblies with Amazon knockoffs
    Blocked off Rodent entry hole under the wiper cowl
  10. ChapmanF
    18,588
    My 2010 hit 200,000 around Thanksgiving. Didn't get around to posting then. Coming up on 207,000 now.
    No and no.
    Yes. Then during the pandemic, I modded the solar roof so it also keeps the 12V battery charged, and haven't had to think about it much since.
    Once so far, around 120,000 IIRC.
    Rears so far (rear rotors too). New fitting kits once or twice, otherwise little in the way of brake repair. I do inspect and measure at every tire rotation.
    Not calculated.
    5,000 miles, which is the interval in the manual for my driving conditions. The level is negligibly lower between changes. I use Toyota's 0W-20, which often beats the price of local alternatives.
    I missed it. Didn't notice till later. (I was really looking forward to a photo at one light-second also, but I didn't catch that moment either.)
    Nope.
    Once, around 150,000. Still blowing 22.78 kPa on the most recent self-test.
    Coolant changes and spark plugs, filters, the usual. Front wipers stopped working once, fixed by rubbing the legs of the WIP fuse with a pencil eraser. Power mirrors didn't work when I bought it, fixed by opening the switch and using contact cleaner (note: a Toyota TSB discourages such repair of switches, only wants you to replace them).
    Replaced one TPMS sensor, at about 12 years. Other three keep on ticking.
    The brake accumulator might have a slow nitrogen leak. I've been doing a bleed procedure when I start hearing bark/quack noises, generally banishes them again for a year and a half or so.
    CR94 likes this.
  11. Jon Batchelor
    Jon Batchelor Junior Member
    17
    FL
    My car's at about 320k miles at this point. Best car I've ever had, and hope to double that with time, if the universe cooperates.
    As an (unfortunate) off-topic aside, in case replies can be seen, while posts can't ... how long does it take to get moderator approval around here? My current post has been sitting for around 7 hours, I think, and my last one sat for two days before I gave up.
  12. Paul Gregory
    Paul Gregory Senior Member
    2,247
    595
    Alberta
    2024 Prius Prime
    XSE
    I don't have any expertise in this subject at all, but it seems to me that corrosion from road salt would be one of the easiest problems to solve, at the manufacturing level.
  13. Bayesian’sMom
    Bayesian’sMom New Member
    Rochester, NY
    My 2012 Gen 3 Four decided at 214,427 miles to blow the head gasket.
    I loved this car as it was the first I purchased on my own. It handled snow like a champ and had great features I picked out.
    Did a full set of brakes at 120,000 if I remember correctly and last year the front brakes got replaced.
    Spark plugs got replaced in 2023.
    Two sets of tires, the most recent was last year.
    Not sure which battery was replaced last year.. . A single battery that cost $300.
    Oil was religiously changed every 5k.
    It started shuddering on the start a couple of months ago and after three times at the shop it was finally determined the head gasket was blown and was causing misfires in cylinders 1 and 2 on starting and sometimes on acceleration. No check engine light for two months after the shuddering started and after two engine scans that did not show anything, it finally gave up the ghost on the third visit to the shop.
    The navigation display also kept changing direction on its own, for example, if I was going straight, the map displayed sideways or upside down. I reset it multiple times and it would always revert to some misaligned view that did not match the road I was driving on. The shop did not know why.
    I decided to purchase a used 2021 Prius Prime LE, which I will take ownership of next week as it was in my price range, the mileage was acceptable to me and I found suitable financing and the price was on the low average for that year.
    And I purchased it because of my love of my first Prius, which had been good to me.
    Hoping this next one is as good to me.
    CR94 likes this.
  14. rjparker
    10,580
    6,636
    The shop should have done a borescope test the first time. Hope they did not throw too many useless parts at it.
    Xterra72 and Bill Norton like this.
  15. Noriman
    Noriman Junior Member
    Ohio
    My 2015 Prius Two hit 230k miles recently. Owned since new, it's been a wonderful vehicle!
    2) Did you replace the 12v battery? Yes, around the 7 year mark. I noticed a sudden drop in MPG, and turns out the voltage was low.
    3) Did you replace the transaxle fluid? How often? Yes, once at 100k miles.
    4) Did you replace the brake pads? - Front brakes at 151k, they were down to 2mm. Rear brakes at 165k--they still had life left but I was replacing one of the wheel bearings and figured I'd complete it while the brakes were off.
    5) Your lifetime MPG (if available)? - Summer around 48 MPG, Winter around 44. This winter was an exception--41 with the brutal cold.
    6) How often do you change your oil? Does your Prius consume oil? No oil consumption. First 150k miles @ 10k intervals and then switched to 7500 miles since then. I use TGMO, Pennzoil, Castrol, Mobil 1 and always with a Toyota-made or high quality oil filter.
    8) Did you install an oil catch can? How often do you inspect or dump it? No.
    9) Have you cleaned the egr circuit? How frequently? I've cleaned the Intake manifold and EGR pipe now twice--155k and 227k miles. Both times they were fairly clean and without any buildup in the EGR pipe. I only had a coating of oil in the throttle body, nothing significant.
    10) Any other maintenance? Two wheel bearings (same side) from Midwest winters and potholes. PCV valve with the first intake manifold cleaning. Regular maintenance per the manual, but I now change coolant every 40k miles. I switched out the head unit to a JVC CarPlay unit with Maestro connection -- huge upgrade, made the driving experience that much better, plus I can now see TPMS, RPMs and engine temps.
