EvGo Charging Station?
Discussion in 'Prime Technical Discussion' started by maiki, Apr 8, 2026 at 12:29 PM.
  1. maiki
    maiki Member
    216
    33
    As I have indicated before, I have no option to plug in the car (2025 XSE Premium) where I currently live, so am dependent on charging stations. (besides occasionally getting a tiny bit of charge from the solar charging roof.) Therefore yesterday, totally out of charge, when I saw a charging station a couple blocks away from where I had a doctor appointment, I thought I would get some charge while at the doctor?
    It was an EvGo charging station. They had cables with two different kinds of connectors, both much larger than the one for my car. (Not the Tesla connector either.) So I could not charge there.
    This also happened recently when I wanted to charge at chargers within a Von's supermarket parking lot. Only one connector, similar to one of those at EvGo, too large to fit in my car.
    As I think the kind in our cars is the most common type of connector (not counting Tesla), why do some charging stations not have a cable that that will fit it? Seems they are losing business that way? (If many cars cannot use their station?)
    Can one obtain some kind of adapter that would enable one to use those different chargers?
    Thanks in advance.
    BTW, speaking of charging while shopping, etc., it is aggravating that Whole Foods (at least here in California) no longer have chargers in their parking lots! (Bezos kissing up to Trump?)
  2. BiomedO1
    4,223
    2,207
    SacTown, Ca
    Your more than likely running into DC fast chargers in So. Cal.. IMHO; it's unwise to hook-up using an adapter to something you don't know what the output is. That's the reason they are different connectors; to prevent stupid stuff from happening. If it's a popular charging spot, there should be a J1772 connector somewhere.
    On my car and my driving style; I've calculated that paying more than $0.38 Kwh is the same as paying for gasoline. That calculation was done @ $4 a gallon of gasoline. In my experience, most charging stations charge way north of that and stack fees on top if it. This also doesn't take into account how long you'll need to hook-up - since these cars are slow chargers compared to other modern cars. Some will add a parking time fee that ticks off every 30 minutes.
    Your car, your wallet, do whatever you like....
    #2 BiomedO1, Apr 8, 2026 at 1:36 PM
    maiki and pasta4breakfast like this.
  3. bisco
    52,419
    public charging is complicated. you should see the confusion over on the chevy bolt forum.
    if you want to learn about public charging, you'll have to spend a lot of time with google, it's a steep learning curve
    maiki likes this.
  4. pasta4breakfast
    120
    58
    Anaheim, CA
    2020 Prius Prime
    You are probably looking at CHAdeMO or CCS level 3 DC fast chargers. I don't think there is a lot of financial incentive to build out much more level 2 chargers. Plug-in hybrids are the only new cars that are limited to L2 public chargers and it is usually more economical and convenient for their owners to buy gas if they need to fuel outside of the home. The DC fast chargers generate more revanue becaue time is money. Even if the owner of the charging station could add J1772 connector to it, why would they? It would probably cause them to lose money. For a plug-in hybrid to even bother charging, the price would have to be less than $0.40 per kWh. Imagine a Prius Prime taking a spot for 1 hour just to spend $1.32 when 3 modern EVs could spend over $100 at a fast charger during that same hour.
    Usually the only economical L2 charging stations in my area are at malls (best chance of getting a spot is before they open) or government buildings (libraries, city halls, parks etc.). Most of the charging apps allow you to filter out any charging stations that won't connect to your Prius Prime. The ones I use the most are JOLT (mostly free charging at malls), charge point (sometimes has reasonably priced L2 charging at about $0.30 per kWh) and plugshare (finds pretty much any charger).
    #4 pasta4breakfast, Apr 11, 2026 at 1:39 AM
    maiki and BiomedO1 like this.
  5. BiomedO1
    4,223
    2,207
    SacTown, Ca
    I've got the plugshare app on my phone, but rarely use it - since my car charges while I sleep.
    I was pleasantly surprised to find a couple of L2 charger in a national park I camped in for two days. They were marked for a specific brand of EV but had J1772 plugs and what looked like a chargepoint screen. I was lock-out of one, but the other did an electronic hand-shake and started charging. I corrected the plugshare data and description, that one of the two is freely open.
    I had to wait for that plug the second day. When I got up; I was planning to recharge while I made breakfast and broke-down camp. There was a Nissan leaf in my spot, but it was almost full - when I walked around it. I guess the owner saw me do that and unhooked as soon as it was done. He commented that he thought it was a EV specific charger and knew about it the last three times he's camped there, but never tired it. I told him I was the one who correct that post. I guess I should've waited, before posting my discovery. :(:rolleyes:
    Oh well, live and learn.....
    #5 BiomedO1, Apr 11, 2026 at 2:35 AM
  6. maiki
    maiki Member
    216
    33
    Those (EvGo) I mentioned were in a bank parking lot, and were all empty. So I don't think they bring in a lot of revenue? Yet they could have earned a little from me if they had a plug that fit the prime.
  7. maiki
    maiki Member
    216
    33
    As I menrtioned Whole Foods parking lots near me used to always have at least one charging station (which fit the Prime), some a few, even up to 4, At first totally free to use, no app, just plug in. Later changed to Shell. Didn't cost much, but the app rather buggy, didn't always work. But now they have removed those, no charging stations at WF stores here at all. Is that true nationwide? Anyone know why?
    For those of us that can't charge at home, it is convenient to be able to add some charge while shopping. Is the government pressuring stores not to have them now? (Since Trump gets loads of money from the fossil fuel industry, petro states like Saudi Arabia, etc.)
