Speaker - Non JBL in place of JBL
Discussion in 'Gen 2 Prius Accessories & Modifications' started by KitsuneVoss, Apr 10, 2026 at 5:41 AM.
  1. KitsuneVoss
    KitsuneVoss Member
    373
    55
    Virginia
    In my 2005 Prius, it has JBL speakers. One of them is blown. Previous owner had the Base maxed. I have a pair of non JBL speakers, at least with no JBL logo. Can I simply replace the JBL speakers with the standard 2nd Gen speakers?
  2. SilentKiller
    SilentKiller New Member
    Yesterday
    St Cloud, Fl
    That is not advisable. Here's why;
    Your factory system uses:
    2-ohm speakers (low Impedance)
    This is NOT a standard setup
    If you install normal speakers (4-ohm)
    1. You'll get Lower volume
    Amp sends same voltage
    • Higher resistance (4Ω vs 2Ω) = less power
    • Noticeably quieter system
    • Weaker bass
    2. Thin / weak sound
    • JBL amp is tuned for 2-ohm load
    • 4-ohm speakers won’t “wake it up” properly
    • You will NOT damage the amp
    • Running higher resistance is safe
    In case you're wondering why Toyota did this?
    • Gets more power from a small amp
    • Improves efficiency
    So my friend, you are stuck with either shopping for 2 ohm speakers, or begin saving for a full upgrade of amp and speakers to a more readily available 4-ohm set up.
    frodoz737 likes this.
  3. KitsuneVoss
    KitsuneVoss Member
    373
    55
    Virginia
    Honestly in such a case the easiest thing is to get a used set of JBL upper door speakers from eBay or see if I can get a pair at a junkyard.
