Just bought a new 2026 EV model. Good m/kHr?
Discussion in 'Gen 5 Prius Fuel Economy & Prime EV Range' started by zzyzx, Apr 12, 2026.
  1. zzyzx
    zzyzx Junior Member
    96
    2026 Prius Plug-in
    This is my 3rd Prius. My plan was to replace it next year but it needed $4k in repairs and they offered me a deal.
    I've mostly been running it on electrons so far and I've moved the running miles per kHr has moved from the 2.4 that it started at to just hitting 4 today. Is that a good number or should I keep hoping for better.
    It's definitely fun to be over 200 miles and still have a completely full tank with Seattle gas prices.
  2. notspam3
    notspam3 Member
    113
    61
    Toronto
    2024 Prius Prime
    XSE Premium
    EV or PHEV?
  3. BiomedO1
    4,295
    2,256
    Left Coast
    Don't know what car your talking about - Prius are hybrids NOT a full EV. The Prius PHEV is a plug-in that runs in either HV or EV modes. You've posted in the gen5 Prius forum; if your car isn't a Prius - Your in the wrong forum. Ask administrator to move post to the correct forum.
    Placing your car in your profile would be helpful.;)
    #3 BiomedO1, Apr 12, 2026
  4. zzyzx
    zzyzx Junior Member
    96
    2026 Prius Plug-in
    Prius plug in Nightshade. I've mainly been driving under 20 miles a day so it's mostly been in electric mode.
    bisco and BiomedO1 like this.
  5. zzyzx
    zzyzx Junior Member
    96
    2026 Prius Plug-in
    I used EV to differentiate from the pure hybrids I've owned before.
  6. BiomedO1
    4,295
    2,256
    Left Coast
    You should have a 38 mile range on that battery. 4 miles/KwH is about average. It'll increase as it gets warmer and decrease as it gets colder. My gen4 is averaging the same; but I'm lighter and have a smaller battery than you. Summer with light AC usage gets up to 4.8 miles/KwH; but I've also seen outliers too. It's reported 25-30 miles/KwH going up and coming back from South Lake Tahoe in the same day; several times already - over the years.
    Make sure you exercise the engine every month or two. Let it get all the way up to full operating temperatures to lube and burn-out contaminates. I manually flip mine into HV mode whenever I'm on the highway for more than 15 minutes. This guarantees the engine will get up to full operating temperatures and gets a good workout; keeping all the cars' systems fully operational.
    #6 BiomedO1, Apr 12, 2026
    zzyzx likes this.
  7. bisco
    52,470
    congrats!
    it's all about your driving scenario. climate, topography, speed, acceleration, hvac use, stop and go, there are too many variables to determine a 'good' m/kwh.
    all you can do is try your best in your situation.
  8. notspam3
    notspam3 Member
    113
    61
    Toronto
    2024 Prius Prime
    XSE Premium
    So far we are averaging about 2500km per PHEV tank in canukistan winter, up to 5000km in summer
