12v reading in ready mode help
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Edrive, Apr 12, 2026 at 9:30 PM.
  1. Edrive
    Edrive Junior Member
    Tx
    Four Touring
    Does anyone know what the normal 12v reading should be when driving in ready mode?
    I bought a gauge that reads out ecu data like temp, volt, rpm, etc and it is showing that the 12v is dropping all the way to 12.0-12.1v while driving!? Intuitively this feels concerning but maybe someone can help me understand if its normal..
    When I FIRST press the brake then hit the start button/ready mode, the gauge reads out 14.1v which seems perfect.. Once I put it in Drive mode/D, the 12v reading starts to drop from the initial 14.1v to what appears to be the resting voltage of my fully charged battery which is around 12.5v.
    I was testing/monitoring it and when I turned on the headlights, blower motor, rear defrost, etc, the voltage began to slowly drop from the 12.5 down to 12.3, then finally going all the way down to 12.1??
    I tested that the gauge reading was accurate by putting a multimeter on the 12v battery and it was....
    I know that the Prius probably has advanced charging logic, but coming all the way down to 12.0v-12.2v feels abnormal...?
    Also, as SOON as I hit the P button to put it in park after driving the voltage IMMEDIATELY jumps back up to 14.1v and will stay at 14.1v for an indefinite amount of time...?
  2. AzWxGuy
    AzWxGuy Weather Guy
    1,073
    552
    Tucson, AZ
    2021 Prius
    I have a device that plugs into the 12V socket in the center console which provides two USB sockets for charging other devices and a digital readout of voltage. When charging another device the display alternates between charging current and voltage. I regularly watch the display when making my Prius ready to determine 12V SOC and when I should connect up my battery maintainer. During the boot cycle there is usually one reading that shows battery under load and DC-DC converter not connected yet. That value is typically 12.1 to 12.4V and will drop as low as 11.8V when it's maintainer time. When made ready, the voltage reads 14.1V, which is a charging cycle by the DC-DC converter. After some time driving, the "charged" voltage drops down and is usually 12.9V. My driving voltage doesn't drop below 12.4V. You have confirmed that your ECU gauge is displaying the correct voltage. It shouldn't matter where in the vehicle a 12V measurement is made, but there may be additional load or other constraints when measuring from the OBD II port, where I assume your ECU gauge is connected. Have you confirmed with your DVOM, from another test point, these lower voltages as displayed by your ECU gauge?
