Quirk in the transmission shifter
Discussion in 'Gen 5 Prius Main Forum' started by HamiltonPrius, Apr 12, 2026 at 11:26 PM.
  1. HamiltonPrius
    HamiltonPrius Active Member
    212
    100
    Parts unknown in Virginia
    2026 Prius
    Has anyone noticed that when you shift the shifter left and forward it makes the car go backwards. Shift left and backwards makes the car go forward……does anyone else other than me think that is backward?
  2. ChapmanF
    18,597
    If you were sitting in a little red wagon, and you reached ahead and grabbed a fence post, pushing forward on the fence post would make the wagon go backward, while pulling the fence post toward you would make your wagon go forward.
  3. BiomedO1
    4,242
    2,222
    SacTown, Ca
    It is, what it is... I always thought reverse polish notation (RPN) was wacky on an HP engineering calculator, but it was called Polish for a reason.:p:cool:o_O Sometimes when I need to work on German or EU equipment, I'll need to reverse the order of things - to understand how it's suppose to work.:censored::rolleyes::sick: I still can't figure out who's brain is messed up - Let me know if you can figure it out.....
  4. PriusCamper
    PriusCamper Senior Member
    13,110
    5,314
    Pacific Northwest, USA
    I know alot drivers I see on the roads these days who I wish would be sitting in a toy wagon pushing and pulling on a fence post far away from roads!
  5. VelvetFoot
    VelvetFoot Active Member
    1,247
    489
    New York State
    2026 Prius
  6. HamiltonPrius
    212
    100
    2026 Prius
    Just not very intuitive IMO
  7. Trollbait
    12,693
    R is above N, and D is below N, just as it is on other automatic transmission shifters.
    The quirks that could make this seem off is that P is separate button and not above R, and the shifter not staying on the selected gear.
    BiomedO1 likes this.
  8. schja01
    schja01 Senior Member
    1,849
    1,228
    Chicagoland
    2024 Prius
    Limited AWD-e
    It’s the same pattern as a “3 on a tree” shifter
    from times passed but laid flat. Toyota has used this pattern on Prius since at least Gen2.
  9. bisco
    52,429
    perennial question from newbies since at least gen 2 :p
