Combination meter going black
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TechBill, Apr 14, 2026.
  1. TechBill
    TechBill New Member
    Missouri
    Our 2007 Prius combination meter is starting to go black. We already know this is a common issue and that the usual fix is replacing the capacitor in the meter.
    What we are trying to figure out is whether the blackout can also affect shutting the car down and the door locks. For example, has anyone seen it cause the doors to lock unexpectedly right after unlocking?
    We ran into a situation at the store where the display went out, and we could not fully shut the car off. We held down the start button and the car would partially shut down, but the display stayed on and the doors remained locked. We could not unlock them to open the rear hatch and access the battery.
    We held the start button for quite a while, but it still would not completely power down. Is there a specific way or button combination to fully shut down the car in this situation so the locks work normally?
    Is all of this related to the failing capacitor in the combination meter, or could something else be causing it?
    Thanks,
    Bill
  2. JC91006
    JC91006 Senior Member
    16,923
    8,634
    Yes it's all related to the capacitor. Once you fix that, it'll all be good.
    TechBill likes this.
  3. TechBill
    TechBill New Member
    Missouri
    Thank you.
    Now to find a time to remove the dash to access it.
    Bill
  4. JC91006
    16,923
    8,634
    There are videos on youtube that can help you with that. It shouldn't take that long to do, however you may end up breaking the vents when you remove them. So you have to be extra careful or source the spare parts before you begin.
    I have a friend that can probably assist with repairing the combination meter and have the spare parts for the vents. If you need help, send me a message and I'll give you his contact info
