"P" shift position vs. PARK button
Discussion in 'Gen 5 Prius Technical Discussion' started by schja01, Apr 11, 2026 at 1:33 PM.
  1. schja01
    schja01 Senior Member
    1,851
    1,229
    Chicagoland
    2024 Prius
    Limited AWD-e
    I've read the manual and am still confused.
    What does the "PARK" button do that the "P" shift position button doesn't?
    If I'm parking on a modest slope is it better to use one vs. the other?
    When I'm done driving I just power the car off. Is that bad practice even on level ground?
    Thanks in advance.
    J
  2. Mendel Leisk
    41,962
    I'm not that familiar with gen 5, but it has electronic parking brake? I'd surmise "P" button "shifts" the transaxle to park, which activates a "parking pawl", a pin that move in, to lock the transaxle from turning, mostly, but the car will be able to roll an inch or two. And it's somewhat "all the eggs in one basket", a relatively weak deterrent to movement.
    On the other hand, if you push the "PARK" button, you've activated the electronic parking brake, which is going to clamp the rear wheels rotor with the brake pads, preventing all back and forth rolling. And it's "belts and braces", protects the aforementioned parking pawl from undue loading.
    My 2 cents, always use the electronic parking brake, but at the least use it when you're on any amount of incline.
    richard schumacher and schja01 like this.
  3. schja01
    1,851
    1,229
    Chicagoland
    2024 Prius
    Limited AWD-e
    Thanks Mendel.
  4. KMO
    KMO Senior Member
    2,014
    742
    Finland
    2023 Prius Prime
    By default the parking brake is automatically applied when you select P anyway.
  5. schja01
    1,851
    1,229
    Chicagoland
    2024 Prius
    Limited AWD-e
    My wife’s Venza seems to work this way my gen 5 doesn’t. I probably changed the behavior inadvertently. I’ll figure out how to change it back. J
  6. KMO
    KMO Senior Member
    2,014
    742
    Finland
    2023 Prius Prime
    You hold the switch in position for a few seconds to enable or disable the shift link. Dash message will acknowledge.
  7. schja01
    1,851
    1,229
    Chicagoland
    2024 Prius
    Limited AWD-e
    Thanks. Working as intended now. J
    KMO likes this.
  8. VelvetFoot
    VelvetFoot Senior Member
    1,254
    490
    New York State
    2026 Prius
    Manual says consider not linking the two in cold weather, but I didn't have any problem this winter.
    2023p likes this.
  9. mingc
    mingc Member
    84
    61
    Portland, OR
    2023 Prius
    XLE AWD-e
    It's not the most well written manual in the world, but as I read it, it says not to use the parking brake at all in cold weather.
  10. Trollbait
    12,695
    It is a general piece of advice. There is a risky of parking brakes icing shut in wet, freezing weather. That said, it hasn't been an issue with any of my cars.
  11. Gokhan
    Gokhan Senior Member
    6,565
    2,619
    Paramount CA
    It’s like any car with an automatic transmission. Force shouldn’t be applied to the wheels when the transmission parking pawl is engaged; otherwise, it will break. Use the parking brake on slopes before you put the transmission in park.
  12. richard schumacher
    7,675
    1,058
    United States
    Where did you get that diagram?
    Gokhan likes this.
  13. ChapmanF
    18,606
    That looks like the kind of diagram you find in the New Car Features manual—that's the one that explains what all the parts of the car are for and how they do it, so when you're reading the Repair Manual you know what it's talking about.
    Toyota Service Information and Where To Find It | PriusChat
    richard schumacher and Gokhan like this.
  14. richard schumacher
    7,675
    1,058
    United States
    Thanks. For printed service manuals TIS refers one to Helm Inc., but they don't have service manuals later than 2011. (They do sell owner's manuals for about $75 including tax, shipping, and handling.) Jeez Louise.
  15. ChapmanF
    18,606
    By the same token, back when you could buy the dead-tree manuals from Helm, you'd spend a few hundred for the repair manuals, something more for the Electrical Wiring Diagram, more if you also bought the New Car Features manual (a very good idea, because it explains all the things the Repair Manual assumes you know) or other extras like the Collision Repair Manual.
    Now, you can pay $30 for two days' access whenever needed and have access to all of that, and it's all interlinked, and the wiring diagram lets you click circuits and follow them everywhere they go, pull up replacement pin part numbers and so on, and also all the technical service bulletins, service campaign announcements, and quick technical guides are there, plus the whole library of "University of Toyota" technician training course books, all included in the one price, as well as all the manuals for your friends' and family members' other Toyota models. Or you can have a month of access for $105—well worth it if you are new to the car and want to get familiar with the manuals and where to look for what.
    And if an error is caught in the manuals, the next time you look online, it's been fixed; you're not carrying around a paper copy frozen in time. (Though people often do pay for a short subscription period and use it to download things for future reference.)
    Also, as that wiki page explains, you may have various options to access all of that for free, depending on where you live, what your local library subscribes to, and so on.
