Got bored today.. modded Tires Deflectors.
Discussion in 'Gen 5 Prius Accessories and Modifications' started by DOHCtor, Apr 11, 2026.
  1. DOHCtor
    DOHCtor Active Member
    170
    103
    Levis (Quebec city's south shore)
    2024 Prius Prime
    SE
    I got bored lately so i modded the Tire Deflectors using old flat style Mud Guards and aluminum rivets i had lying around. Will that change something? That remains to be seen.. But at least it's reversible if something doesn't turn out as planned.. I'm kind of happy with how the rear ones turned out to be. It's almost OEM+ looking!
    Messenger_creation_E9D4F656-7421-4936-8848-70C49CC89712.jpg 20260411_125507.jpg 20260406_200821.jpg 20260406_201234.jpg
  2. Mendel Leisk
    42,345
    These are ahead of, or behind, the wheels? Hard to tell; I’m guessing ahead.
  3. bisco
    52,849
    on the hycam, they are behind, iirc. we hit something on the highway at night in Georgia, then there was a horrible scraping sound and I thought we were toast.
    pulled off into a shopping plaza and crawled under with a flashlight. turned out the deflector only had one screw and had swiveled against the tire.
    but yeah, those look to be in front
  4. notspam3
    notspam3 Member
    138
    74
    Toronto
    2024 Prius Prime
    XSE Premium
    Lucky for you they don't salt roads in Quebec
  5. DOHCtor
    170
    103
    2024 Prius Prime
    SE
    They do less then they used to do but still do a bit... now they throw gravel on the road, not that much better.. my 6months old car would need a fresh coat of paint in the front end.. it's that bad!
    As for the spats, yep, in front of the tires! Nothing weird to declare so far.. temperature swings like crazy so hard to tell if it changed anything but...
