HELLA 011225881 horn in a 2024 Prime?
Discussion in 'Prime Accessories and Modifications' started by Scott_R, Apr 2, 2026.
  1. Scott_R
    Scott_R Member
    441
    Long Island
    2024 Prius Prime
    I'd been looking through the threads about replacing the golf cart horn in the current generations of Priuses, when I recalled that I had this horn set in my basement--I'd bought it for my 2102 Prius but never got around to installing it. It's this:
    https://www.amazon.com/dp/B00BODVOSY
    Would this work at all? I know I would need a harness in order to add both; the horn has the Toyota plug. If it's possible to use it, where could I buy just the harness and the mounting hardware? It has the bracket but I'd need a second bolt. Anything else?
  2. Garen
    Garen Junior Member
    58
    Sherman Oaks
    2019 Prius
    if it has a Toyota plug just plug it in and use your original hardware.
  3. Scott_R
    Scott_R Member
    441
    Long Island
    2024 Prius Prime
    It has the 2 horns (350 & 420 hz) to I would need a new harness as well as mounting hardware.
