Canola fields
Discussion in 'Environmental Discussion' started by bwilson4web, Apr 15, 2026.
  1. bwilson4web
    16,516
    Usually we see corn, cotton, alfalfa, and soybeans this time of year. But now I’m seeing yellow canola fields. Another success of tariffs.
    Affordable farm labor scarce, diesel high, and a different crop … I don’t envy North Alabama farmers this year.
  2. hill
    9,018
    Ah yes rape seed oil. Gee I wonder why they don't call it rapeseed oil instead of canola
    unprocessed rapeseed oil from traditional high-erucic varieties can be harmful — often contains over 40% erucic acid, which in animal studies cause fat buildup in the heart muscle. Yeah that's what I want. So mankind does what mankind does best . Monkey with genetics - they bred low-erucic strains for food use, now under 0.5% in most commercial rapeseed oil.
    That's partly why all the health food nuts have switched to more organic types of oil.
  3. bisco
    52,803
    supercharge your soil! watch
  4. VelvetFoot
    VelvetFoot Senior Member
    1,407
    545
    New York State
    2026 Prius
    Biodiesel!
    bwilson4web likes this.
  5. hill
    9,018
    Modern diesels allow no more than a 5% blend in the winter time - as it will clog filters injectors (wax up) & void the warranty
  6. Trollbait
    12,814
    In the right blend, B20 will work in below freezing temps. Only Ford and GM of the car makers says it is okay to use B20 in their half ton trucks and cars though. Going above that in a Ram or Jeep calls for shorter maintenance intervals. European brands say no higher than B5.
    Renewable diesel, or hydrocracked vegetable oil(HVO) is made from the same feedstocks as biodiesel, yet doesn't have the drawbacks as it is closer to diesel chemically.
