How expensive is the flat tire charge, if you have no spare?
Discussion in 'Fred's House of Pancakes' started by Georgina Rudkus, Apr 13, 2026 at 10:04 AM.
  1. PriusCamper
    PriusCamper Senior Member
    13,123
    5,318
    Pacific Northwest, USA
    Nitrogen is what Costco uses... That's ok to inject. :) Of course Costco Membership dues are getting more expensive.
    BiomedO1 likes this.
  2. BiomedO1
    4,254
    2,233
    Left Coast
    OK fixed; replaced air with gases
    PriusCamper likes this.
  3. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,516
    2,505
    Taylors, SC
    Gates fine; hardening liquids; NO!
  4. Zeppo Shanski
    Zeppo Shanski Active Member
    305
    164
    Chicagoland
    I recommended "Fix-A-Flat" for a RIGHT NOW REPAIR. It works DAMN WELL RIGHT NOW. There is NO RECOMMENDATION for driving with it forever. You go to a place to fix your tire and let them know. It does get messy ... BUT ... I've never seen it harden up making any problem for repair except for being messy. Think whatever the fvck you want. YMMV.
  5. PriusCamper
    13,123
    5,318
    You run the risk of a shop refusing to repair your flat because the tire is now contaminated in ways that will interfere with the patch adhesive working, as well as locating the leak. What's more a $5 tire patch kit and a bike pump can fix most flat tire damage permanently in just a tiny bit more time so when you pull away from the side of the road you're done. No visiting a tire shop to have them clean up a mess, you just keep driving.
  6. Zeppo Shanski
    305
    164
    Chicagoland
    SO ... someone's 82-yo wife/mother/GF is just gonna hop out and use that "$5 tire patch kit and a bike pump" easier than just spinning on a spray-can repair?!? I'm absolutely sure that the repair places IN YOUR LOCAL VICINITY are going to refuse repair, because well ... they just will. NOWHERE in the general CHICAGOLAND AREA have I ever seen that happen. And I'm also absolutely positive that NO patch adhesive will work because again ... they just won't work. NEVER have I ever seen that happen when proper repair procedures are being followed. Since I've been a member here, every fvcking suggestion I make has some expert mechanic like you telling me I'm wrong. Every time I have to apply the Bactine and Band-Aids to my wounds because you're all fvcking geniuses that must have been working on cars longer than me (+/- mid-'70's). Most of the said fvcking genius expert mechanics haven't ever fixed anything other than replacing an air filter. You all have the fvcking stupid ideas that everything MUST be replaced with OEM Toyota parts from the local dealer ... even though you refuse to believe that Toyota doesn't even make many of those parts and gets them aftermarket in the first fvcking place. I sincerely apologize for stating anything that goes against your over-the-fvcking-top mechanical repair knowledge. WTFDIK.
  7. PriusCamper
    13,123
    5,318
    Someone's 82-yo wife/mother/GF isn't going to know how to use a can of fix-a-flat either... They call for help and whoever shows up for help desrves to have a tire patch kit and air pump in the car.
    And before you increase your blood pressure any further with a temper tantrum based on anecdotal information and zero verified references, please realize that I thoroughly referenced my points in post #33 of this discussion. I also forgot to mention to you that Fix-a-flat can damage your tire pressure sensors too.
    Lastly, your cursing tirade failed to recognize that I'm on record on here over the past dozen years that more people need to buy the cheapest aftermarket parts and examine them and test them for the benefit of the greater PriusChat community so we don't get ripped off by OEM when an equal quality non-OEM part exists for less. 95% of the time non-OEM is adequate for an old Prius.
