Airsoft BBs in tires for balance
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Priipriii, Nov 28, 2025.
  1. Priipriii
    Priipriii Member
    231
    67
    Has anyone done it? I was looking online researching balancing beads and they work well from what i took away. But, actual balancing beads are fairly expensive for what they are and i asked chatgpt if i was able to substitute rice instead, and it told me why that was a bad idea. Instead it offered 6mm BBs, 500 per tire, you can buy a can of 5000 for $15 vs balancing beads at $40 and they hold the same properties of being water resistant and what not.
    Anyways, i do my own mount and dismount of tires at home and the issue i been having was they are always out of balance afterwards. Even when i try to balance them with the sticky pad weights using a cheap harbor freight balancer, its never on point. I think ill be switching to beads on all my tires from now on. Just wondering what the driving experience is with them if anyone has them right now before i attempt this.
    Tande likes this.
  2. Misterman74
    Misterman74 New Member
    27
    Fresno
    2018 Prius
    Are you like totally off grid or something?
    -the balancing beads rolling around inside the rim is for dudes on the farm with the cheap mud terrains. (Cheap mud terrains are notorious for taking a lot of weight in multiple places)
    I imagine anything in the prius rim would devastate the tps's.
    mount your own: cool
    Balance your own successfully: cool
    If you cant get it, take it to someone who has a $35k machine that gets it right the first try.
    Brian1954 likes this.
  3. Hayslayer
    Hayslayer Active Member
    490
    279
    Crack open the welded wallet and have them professionally balanced. Stepping over a dollar to save a dime..........
    Bill Norton and Brian1954 like this.
  4. notspam3
    notspam3 Member
    117
    63
    Toronto
    2024 Prius Prime
    XSE Premium
  5. BiomedO1
    4,333
    2,276
    Left Coast
    The independent tire shop, about two miles from me did my spare, mounted & balanced for $20. No breaking my back or scratching that aluminum rim. I did install it on the front driver's side and ran it for about 5 miles; to check their work.
    Hey; can I get some of those beans.:eek::LOL::ROFLMAO::whistle::censored:
  6. BiomedO1
    4,333
    2,276
    Left Coast
    @notspam3 I just got finished rigging the hose from the drivers seat into the gas tank. Now I'm just waiting on those beans..... Who needs gasoline???:cool::p:D:LOL::ROFLMAO::whistle:
