How much is your local "Trump at the Pump Tax?"
Discussion in 'Fred's House of Pancakes' started by Georgina Rudkus, Mar 26, 2026.
  1. bwilson4web
    16,391
    First gasoline purchase in 2026:
    The housekeeper forgot to plug-in the BMW i3-REx one evening. So she burned a little gas.
  2. BiomedO1
    4,259
    2,234
    Left Coast
    LoL; she's just trying to make sure your gas isn't going stale....:cool::D:LOL::ROFLMAO:
    FWIW; I'm only a dollar more a gallon here in the Left coast. Two if your down in LA or SF.:whistle:
  3. pasadena_commut
    pasadena_commut Senior Member
    2,897
    873
    Southern California
    A bit of a possibility if 4.5 months into the year is the first new gas and we don't know how long before that the last fill up was. Might or might not be a problem for the car, but given that the car is BMW and their repairs tend to be $$$ it might not be a terrible idea to be sure most of the gas is burned off at known intervals. How long that will be would depend in part on how much ethanol was in the gas. E10 supposedly starts going south in as little as a month. Also, that's only half a gallon for a 2.5 gallon tank. Not sure that changing 20% every 4 months is enough to keep the tank "good".
  4. Mr.Vanvandenburg
    1,358
    597
    2020 Prius Prime
    About six years ago, maybe more, I bought my 96 Toyota with a bad head gasket and it took me over three years to fix the cylinder head myself. The e10 in there was the same gas I got it with. The truck was sitting a long time when I got it. It started up, ran fine, and I immediately took it to be smogged with my non op travel permit from DMV. Passed smog easily. I was going to change the fuel filter but never did. Right now the gas must be over six months old. E10 having 10% alcohol is better than without. I haven’t had gas problems with E10, but did in the old days before it. At least until I voiced my opinion about it here.
  5. pasadena_commut
    2,897
    873
    Southern California
    96 was before cars were required to be able to run on E10. Was that model advertised as being able to do so? Because many older cars had major problems after they ran on E10. Also, over 3 years the water/EtOH phase should have largely dropped to the bottom of the tank with the gasoline floating over it. That gas should have been almost unusable, even with stabilizer added. See this video:
  6. Trollbait
    12,698
    Older cars likely had problems because ethanol is a good fuel system cleaner, and it loosened up the build up of gunk from straight gasoline the cars had, leading to clogs and other issues. It could corrode aluminum parts in the fuel system. The fix for that is adding a little water to the ethanol.
    Outside a humid environment, a properly sealed fuel tank shouldn't be letting in enough air for water content to reach phase conditions. Without high humidity, the water content of ethanol stabilizes @95%. Most of the water in fuel ethanol was from being picked up along the way in the various tanks and lines it went through before getting to the car's tank. If there is too much water in the tank, the solution is to add more alcohol to get the phases to recombine.
