Shaking when ICE kicks in
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Aadilish, Jan 29, 2024.
  1. BiomedO1
    4,295
    2,256
    Left Coast
    According to your profile; yours is a gen3 - slightly different setup and know head gasket issues.
    If your car is indeed a gen3; please start a new thread in the gen3 forum. You problem may be a bit more severe.
    Good Luck...
    michaud85 likes this.
  2. michaud85
    michaud85 Member
    71
    48
    Maine
    2018 Prius
    I just bought a gen 4 :) I did start a new thread as well. Will update once I get gaskets and clean the EGR valve.
    BiomedO1 likes this.
  3. BiomedO1
    4,295
    2,256
    Left Coast
    Setup an account on Toyota.com. If you enter that VIN; you'll be able to see what the dealerships has done to the car and read their reports.
    Good Luck.....
  4. BiomedO1
    4,295
    2,256
    Left Coast
    The person I refereed to in post #18 was well north of 250K+ miles; the gen4 EGR doesn't clog up like the gen3 with proper maintenance. His car threw a code and according to this thread and person, no codes was thrown; So I would have to question the mechanic's aptitude and test equipment they used. At a minimum, a pending P0300 should've been triggered; when testing in the sweet spot; while it was happening. IMHO and experience. This issue wasn't intermittent and was repeatable at low rpms; it shouldn't have taken 2 years to nail down - IMHO.....
