Rear wheel bearing
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Skitchin1, Apr 5, 2026.
  1. Skitchin1
    Skitchin1 New Member
    Michigan
    I just did a rear wheel bearing on my 2017 Prius. To get the bearing off I bought a 8 1/2 in 3in bolt and nut and 2 washers one being grade 8, and 2 5/8 nuts as spacers. Put it thru one of the holes and tighten it down on the top brake tab. Tell the bearing moved and the bolt got as tight as I can. Hit the bearing with a hammer a few times around it. And it just popped off. The fastest bearing I have ever done. I live in the midwest.
    michaud85 likes this.
  2. Fubar XIII
    Fubar XIII Member
    72
    42
    Metro Detroit
    I'm looking to replace my rears now, actually got parts in the cart on another tab.
    But what size is the wheel nut? 29 - 35 mm sockets are available. I THINK 30 is correct but not certain. In fact, it's why I'm here today.
  3. ChapmanF
    19,045
    What, you mean the socket size for the nuts holding the wheel on by the hub studs? 21 mm on my gen 3 (and my former gen 1, and on gen 2s I've worked on).
    29, 30, or 35 would be yuuuge for wheel nuts.
    Or do you have an AWD model where you're thinking about an axle nut on the rear?
    Fubar XIII likes this.
  4. Fubar XIII
    Fubar XIII Member
    72
    42
    Metro Detroit
    It's FWD. The nut in question would be the center axle nut, not the lug nuts or the four holding it on.
    Wait, do I not have that on the rear? 'scuse me a second.
    I just looked at the part picture and there is no axle nut showing. So, I looked at several others and saw the same thing.
    Having read your reply and giving my gray matter a few hours to think on it, I appear to have jumped to an erroneous conclusion. It makes no sense to have a axle nut on a non-drive axle.
  5. ChapmanF
    19,045
  6. Mendel Leisk
    42,365
    I was gonna suggest a caliper for measuring that rear axle nut. :unsure:
  7. Fubar XIII
    Fubar XIII Member
    72
    42
    Metro Detroit
    Don't own one. I do have measuring tapes with millimeters on them, tho. Would get me close enough.
