I've wanted to, for some time now, give you all a rundown of what I've experienced because I suspect few of you have racked up the miles I have. Admittedly, it feels a bit indulgent, even braggy, but not my intention. Here goes. 318,000 miles in 8 yrs & 2 months. Problems? Very few. Brakes replaced at 230,000 miles. Should have gone closer to 200k as a few pads were getting scary thin. Pics available if you want. The drivers seat covering, left bolster and behind right shoulder, have recently worn through. I need to find an upholsterer, I guess. The paint on the spoiler and the clear coat on the roof are going and the clear coat on the hood at the break is following suit. There is also a little rust just above the windshield, likely due to gravel thrown up in FL. I will need to get that dealt with reasonably soon and then repaint. It'll get professional detailing at that point, too. You should see the dirty headliner! I wore out the top of steering wheel due to my typical one-handed style. Bought a cover. A tie rod end is now showing wear as well and the sway bar links and bushings need replacing. I had the motor mount replaced in January, my first actual repair. Until then, just oil, filters, tires, wipers & PM. Spring will be expensive, relatively speaking. Still on the original shocks! And both Sarasota and Detroit have their more-than-fair share of speed bumps, humps, tables, etc. I typically take them at about sub-10 mph for the gentler rubber humps, about 2 mph for the more abrupt asphalt bumps. One is starting to show a bit of wear and I expect to replace them in the next few (warmer) months. I have never had or needed a front end or four wheel alignment. Every bulb and fuse is still original. I've replaced the starter battery twice, both in FL. Heat kills them faster than cold. Until the latest tire installation in October I've averaged 56-57 mpg. This car has been a dream. Proof that quality design, parts and assembly yield a quality product. The people in Hiroshima deserve a huge round of applause.
An update. June, 2025 333,000 miles down 1. I just replaced the rear brake pads for the second time. This set only made 105,000 miles (~2.3 yrs) but I think they were semi-metallic. 2. Rear shocks have been replaced. Not that they needed to be, but I was replacing the front and rear sway bar links and since I was ordering parts and going to be in there anyway... BTW: The rears are sneaky! You must disconnect the upper control arm to get the bottom on. It's only a couple of degrees but the bolt angles down and there is NO wiggle room. 3. The front struts are being difficult to replace. The 22mm nut/bolt combo doesn't want to loosen. I've dosed them with penetrating oil 4-5x and they haven't budged. I am not a tiny person, 6'5", 270# & strong. I heard the car slip on the jack stand (just a mm or so) so you know I was giving it my all. I'll hit them again when I do the front pads this weekend.After that, a blow torch seems in order.
Thanks for the write up, regarding the seat, I swapped seats with a wrecked car before, I would recommend doing that first but not sure how the airbags and all that works, sure someone else might be able to chime in on all that. For my 2003 Matrix it was an easy Unbolting and rebolting job of 4 bolts. I am less than 1/2 way to your mileage and not really any maintenance to report other than swapping of fluids, never did my brake fluid but have been doing my transaxle fluid.
A follow up. Got the struts replaced using a borrowed cordless impact wrench driver (the guys at Midas love me, so many oil changes). Those two 22mm bolts came off in about a second each. both struts replaced in under two hours. Easy peasy. I'm at 353,000 miles now, a month shy of 9 yrs owned. Went in for my annual Michigan-required Uber inspection in late September. The tie rods were worn to the point of not passing. Had those replaced the next week, inner & outer ($75 on RockAuto, shipping included). Got a four wheel alignment done after. The first alignment I've had. Two weeks ago I started hearing a noise from the rear that I'm almost certain is wheel bearings. (My ex had them going on a previous car.) So that is next. Right now, my ride is sitting at the auto body shop getting the right rear door fixed after a low-speed collision in May. After that, some spots of rust have started above the windshield from gravel strikes in FL years ago. Once I get that dealt with, a full body repainting. Happy Turkey Day, aka, American Overeating Day
The goal is to keep her running well until I get back into driving tractor-trailers. FL is giving me crap on my CDL so Uber is my income still until we get that sorted. Had to buy a rear seat cover as it was wearing noticeably and the light tan interior is a bitch to keep clean with 15-22 people sliding their posteriors across it 5 days a week. I'll install it when I get the car back Dec 1.
Interesting update: Had a slow leak fixed last Friday in my left front tire. The shop told me they found some "slop" in the front end. I had noticed a bit of noise and was trying to determine the source. Had planned to jack it up Saturday to check out various bits, see if any loose bolts, nuts, etc. Culprit? My front anti-sway bar links, replaced just last April, need replacing again. Only got 50k miles on them. That ain't right, man. Otherwise, all is good. Looking at new tires in a couple months (the Hankooks are warranteed for 90k, got 75k on them now. Want to go back to the LRRs for my MPG but will check out all relevant factors first before buying set #6. I'm now at 371,000 miles.
I average nearly 200 miles a day doing Uber, but that is only 5 days per week. Weekends are mostly spent at home or on the motorcycle - in the appropriate months. I tend to do my errands on the way home Monday-Friday so I minimize the non-tax deductible driving. And since my sister moved farther away I will occasionally rent a car for the trip to Indianapolis during the holidays. I'm planning a trip to there & FL in November, that'll be a rental, for certain.
