Help plug identity.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by RavenPri, Apr 20, 2026.
  1. RavenPri
    RavenPri Junior Member
    31
    North West California
    There is a wire harness with no home in the engine bay. Passenger side near the washer fluid fill. I am thinking it might be for a feature on a different model. 2012 model two.
  2. ChapmanF
    18,869
    It helps a lot if you can get a pic showing the wire colors going to it.
  3. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,753
    1,782
    Bay Area
    Is the plug for the washer fluid reservoir plugged in?
  4. RavenPri
    31
    I would assume so as the washer works.
    The wire is taped up with electrical tape in three spots against itself in a U shape. one is right at the clip, halfway-ish and the other is closer to the U. If it was untapped it would reach to the hood lock mechanism. The tape looks installed better than anything I would have done during head gasket replace to keep it out of the way. All the lights work and there are no codes present.
    Just two wires, red and black/white.
  5. NutzAboutBolts
    1,753
    1,782
    Bay Area
    Im not too sure what that is, I wonder if it’s an after market wire. Are you able to follow where it ends?
    I checked the area and mine doesn’t have that wire, the closes one I could find was the one by the hood latch.
