Normal brightness of amber markers in headlight assembly?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by pasadena_commut, Apr 22, 2026.
  1. pasadena_commut
    pasadena_commut Senior Member
    2,922
    880
    Southern California
    While waiting to pick up a passenger at night, parked on the side of the road where it was very dark, I happened to turn the headlight switch one click towards "on". This lights up the front amber lamps at the top of the unit on each side. Except I couldn't see any evidence of that on the sidewalk or street. On returning home pulled into the driveway behind another car, tried one click again, and this time the amber lights could be seen to light up, but the reflection was very dim. I had my son look at them and he said they also looked very dim when viewed directly. Like "why would they ever make it that dim"? The normal and high beams were the expected brightness when that switch was at two clicks. The outer plastic is clear, no significant cloudiness.
    I don't think I ever looked at this bulb at night before, so not sure if these were always dim (perhaps not the right bulbs installed?), if the bulbs are getting old, or some other problem, like burnt sockets. The car was in READY for these tests, with the inside voltmeter reading 14.1V, so not a low voltage issue, at least systemically.
    Or maybe these amber corner markers are always dim and there is no problem at all?
    Edit: looking out the front window, if the "door lock" button on the fob is pressed the amber lights are much brighter when they flash. From this distance I cannot tell if it is the same light coming on though.
  2. dolj
    dolj Senior Member
    8,600
    4,363
    Wellington, New Zealand
    I don't know if I can be all that helpful, as our headlight lenses are completely clear. Our side lights (as they are called here) are white. The indicators are orange, and that is done by way of an orange lamp. There are two different bulbs for each. The details are in the owner's manual:
  3. ChapmanF
    18,661
    Conventional incandescent light bulbs are always (well, when they're on) slowly 'boiling' metal off of the filament, and the metal vapor wafts around inside the bulb and some ends up on the inside of the glass.
    When you look at one of these small bulbs with many many hours of operation on it, the glass can look really dark gray or, like, silvery black from the metal deposited on the inside. That'll make it a lot dimmer than it was when it was new.
    Mendel Leisk, Brian1954 and BiomedO1 like this.
  4. Tombukt2
    13,545
    2,440
    The flash to Park lights are your turn signals much brighter the lil 194 markers even my led aren't that bright.
    BiomedO1 likes this.
  5. BiomedO1
    4,310
    2,260
    Left Coast
    There is NO high-low on marker lamps, just the bulb's luminescent rating. I suppose you can have a bad ground, dimming the incandescent bulb's light output. That effectively acts like a resistor in the circuit. If you only live a few blocks from the ocean, that may be the issue. The salt air rusting your ground point.
    You can check your bulbs and wiring, if you like - but I'm assuming it's a non-problem. IMHO: You should replace the 194's with it's LED equivalent, while your there, since they're cheap ($4 for 30x). That would be a planned preventive measure.
    30x T10/194/168 White LED License Plate Interior Light Bulbs Super Bright 6500K | eBay
    Good Luck....
  6. pasadena_commut
    2,922
    880
    Southern California
    This morning confirmed that the "lock door" button amber light is a different and much larger bulb than the marker light. Oddly the bigger bulb itself is amber colored while the smaller one appears to be clear behind amber plastic. The little bulb as viewed through the amber headlight plastic does not appear to be dark like the one in ChapmanF's picture.
    Regarding those LED replacements, are they visible from the side of the car when lit? The stock bulb is essentially omnidirectional, but surface mounted LED bulbs are usually pretty directional, with most of the light going along the normal vector to the chip and little emitted in the plane of the chip. For LEDs below the plane of the chip is typically completely blocked by the circuit board, whereas an incandescent can emit a fair amount of light "backwards", unless it is blocked by some part of the headlight. (The hot part is way up in the glass part of the bulb.)
  7. ChapmanF
    18,661
    Some of the LED retrofit bulbs have a bunch of LED chips pointing different ways. Some might work out well.
    So far, I haven't gone down that rabbit hole with my 2010 ... the incandescents work well enough for these little incidental lights, so far I've only had to replace maybe three in the car's 16 years, and I actually have a bunch of spares accumulated over a lifetime of driving other cars that used them.
  8. BiomedO1
    4,310
    2,260
    Left Coast
    I replaced my interior incandescent bulbs with 6K wavelength LED's on all my cars. I'm getting old and those bulbs makes a big difference when your trying to read something. There's a reason why all new flashlights are LED's - brighter and longer battery life.
  9. ChapmanF
    18,661
    Sure, all my recently-purchased flashlights are LED. That's the way they were designed and built, and they work great.
    My 2010 was designed and built with LEDs for most small sources inside ... thankfully, no more taking apart instrument panels to change little tiny light bulbs for indicators. They did still build it with incandescents for things like dome lights and many of the outside lights (but LEDs for tail and stop lights).
    I get lots of ideas for projects I want to take on, and so far, selecting suitable LED retrofits to revise all of those original build choices just hasn't risen to the top of my list. Or particularly close to it.... Nothing against other people who want to.
    If my dome light ever burns out, I might do something else there. It isn't subject to any of the "is it DOT street legal?" considerations that apply to the mandated outside lights.
    I would still want it to fade gracefully the way the original does. Some LED retrofits will, and some won't.
  10. BiomedO1
    4,310
    2,260
    Left Coast
    That's weird; I think all the interior bulbs on my 21 Prime was incandescent. I didn't check the instrument cluster, but I'm pretty sure it's LED backlit. I think even the vanity mirror lamps was incandescent; I don't remember - since I did it so long ago.
    I can say with certainty; if I open my door at night - people will be able to see my door marker lamps. I recall that they seem to be at least twice as bright as the old 194's - that I thought about putting red or amber film over them.
    YMMV
  11. Tombukt2
    13,545
    2,440
    My gen2 parked next to a gen3 of say 10 or 12 vintage you can tell the brightness of all my lights on car to the gen3 is quite noticable. Even in ceiling and visor locales . The trunk mite in my gen2 now actually lites the trunk
  12. BiomedO1
    4,310
    2,260
    Left Coast
    Yes; vast improvement in the trunk - with that single 194 on the passenger side wall. Roll back the cover to get some dome lamp action going. But the main reason for the change was those map lamps; once that was done all the other interior lamps just looked inferior - So I did them all for consistently sake. I believe almost all of them were 194/168 sockets except for the dome lamp. As I stated earlier; 30x for $4; so it was just labor. At that price; if I get a couple of duds - no big deal.
    PS They are polarity based; so you need to test as you go. I had to reverse a few, but testing as I went - meant I didn't have to take it apart again. Dangle, making sure there's no shorting path - turn-on - then reassemble.
    #12 BiomedO1, Apr 22, 2026
  13. ChapmanF
    18,661
    Yeah, I think my gen 3's interior dome, mirror, door, hatch lights are all incandescent still. But there's just a handful of those, a number that pales in comparison to all the indicator and illumination lights lighting up everything in the dash, steering wheel, dash switches and power button, armrest switches and so on. At around this age for the car I'm very thankful those are all LEDs. I've taken a gen 2 dash apart to change the light bulbs in the power button and shifter and park button and so on. Won't have to do that here.
  14. pasadena_commut
    2,922
    880
    Southern California
    The only problem with LEDs on dashboard displays and the like is that since they are surface mounted if they ever do burn out they will be extremely hard to replace. By which I mean, take it to a person with a hot air workstation, because removing those tiny things with a soldering iron is like performing brain surgery with a machete. I have a couple of soldering irons, and even a desoldering iron, but no hot air workstation. I would also need a dissecting scope to see what I was doing. It's a big enough investment that I would surely end up paying somebody else to do it. The shops that work on cell phones and laptops have this equipment. I bet very few mechanics do though.
  15. Tombukt2
    13,545
    2,440
    You just replace the cluster plentiful generally .
  16. BiomedO1
    4,310
    2,260
    Left Coast
    Your also assuming that your hand is still steady enough to do that kind of delicate work. That stuff is getting smaller every year. My old job site has that equipment; but no-one beside me has ever used it. A couple of my coworkers has the skill level; but we mostly concentrate on repairing power supplies components - because the components are larger and you don't need schematics to figure out.
    @pasadena_commut; I was the guy with that machete soldering iron on those early surface mount boards. The last few years we were able to get schematics out of vendors - before they started calling it propriety information. You had to really dial back the heat, so you don't lift the pad.:eek::whistle:
  17. pasadena_commut
    2,922
    880
    Southern California
    This video shows a bunch of entry level SMD work
    It gives me nightmares. The components dance around on the board as the solder melts. Smear a big blob of paste over an area that holds two devices and four pads. It miraculously shrinks down to cover just the pads. (Except when it doesn't because too little or too much paste or oops, the air velocity is too high and the components are now sticking somewhere off to the side to other components.) Assembly is straightforward - if you have the template. Then just shove paste through the holes like putting grout between kitchen tiles, drop the components into their proper locations on the paste, heat it up, and clean it up. Rework though, yuck. Smear flux over anything that shouldn't be destroyed, heat it up with the right nozzle (which you will know "from experience") until it pops free - but don't apply too much force to test. Clean it, smear paste over the pads, drop on the replacements, heat up, clean up. Solder bridges? Not for a pro, for me, pretty much guaranteed.
    This all probably becomes second nature if one does this for hours a day for a while. Once every two years though, without ever having put in all those learning hours, not a great idea.
