Hey Yall, I recently got a 2008 prius that was imported from Japan. And finding out the main key fob drains the battery after like 3 days and the 'spare' doesnt work at all. And so I'm looking to get a new fob and use the chicken dance method to program it. The issue is that I cannot find my exact key model. My fob is a black logo with two buttons, so no panic button. It is basically impossible to find the exact model (B21TA). I've found after market B23TAs and was wondering if anyone knows would these work? Or would a normal 2nd gen fob with the panic button work on my model. Apologies if there was already a thread on this I could not find it. Thank you.
I'm assuming the battery to which you are referring is the 12 V battery, not the battery in the fob. Can you confirm? If that is the correct assumption, what makes you think the fob is draining it?
It is the battery in the fob. 3 days after just changing the fob battery it will no longer lock or unlock doors, but the car will still start.
Did you check the battery voltage with a voltmeter to confirm it was 3.2 V? It wouldn't be the first time a freshly bought battery was flat.
It may or may not apply in the OP's case, but some newer coin batteries, especially Duracell, Rayovac, and probably some others, are now coated with a "bitterant." This is an unpleasant-tasting material intended to keep small children from swallowing them. In some cases, this material is thick enough or non-conductive enough to cause a device to believe a newly installed battery is weak or not present at all. We discovered this when our Apple Air Tags failed to recognized brand new, fresh batteries. The solution is to give the battery a few swipes with an alcohol prep pad to remove the coating. Depending on the brand, bitterant might be applied to one or both sides of the battery. Hope this helps.
Thanks for that, I just happen to change my battery last night and discovered that the car still doesn't recognize the remote from distances outside of the car. Shows the key is not present. I think that could be the problem as the pack complies with child safety and it took me three days to open the pack .. lol Thank you
I will give this a try but, after taking a closer look at the fob, it seems like someone has opened the fob before and superglued the housing shut..... I think that might be causing the battery to die out? I bought a used OEM fob off ebay and tried to program with the chicken dance but the anti-theft light is flashing a 2-3 pattern when i slot the new fob in for programming for a minute then goes back to regular flashing. Any ideas what that could be?
Regardless of whether you use Techstream (or a comparable scanner) or the 'Chicken Dance', you can only program a used key to start the car in the slot. To get the other functions, the fob needs to be new, or virginized so it is like new. I don't believe there is a process to virginize Gen 2 fobs.
Seems very unlikely that the fob was glued shut, but opening it is a bit like trying to figure out a puzzle box. It's easier if you have three hands! First, you have to slide that little spring-loaded latch next to the key ring and pull the metal emergency key out of the fob. Then, you have to slide that latch over once more and while holding it in that position, insert the metal key into the opening from the side and use it to slide the fob's back cover off. Then, you'll need a tiny Phillips screwdriver to remove the four screws from the inner cover to access the 2032 battery. My explanation might not have been very helpful, so here's a YouTube video that demonstrates the process. Hope this helps!
