Help finding Wy/CO/NE shop for EGR + other 200k mile tasks
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Wyomingirl, Apr 22, 2026.
  1. Wyomingirl
    Wyomingirl New Member
    Wyoming
    2014 Prius v wagon
    My 2014 V turned 200k miles recently, and so I was looking at the forum trying to figure out which maintenance things I should do. I got the car with 60k miles, and I've done mostly all highway miles on it to get it over the 200k mile mark. For those who helped last summer, I got the famous death rattle and early HG warning. I found a wrecked 2015 with 55K miles and a local shop put that engine in (10,000 miles ago now). I've done oil changes and new brake pads, and a new 12v battery a few years back. The ATF has never been changed, as best I can tell. And I don't know if the new/used engine came with the EGR or exhaust manifold, but something in my mind says I should get those cleaned. Also, I'm guessing the water pump is still my old one (doubt that came with the engine swap last summer-but not sure what the signs would be that I need to replace it).
    I've looked at the videos for the EGR cleaning and manifold steps, and it looks pretty hard. I do my own oil changes, and brake pads, and I'm medium hard-handy, but don't have a shop--just my scissor jack in the driveway.
    I live in WY, and am looking for 1) tips on what I should be doing for my 200k mile birthday spa for the V, and 2) if there's a shop within 300 miles of Laramie, WY that is good with the V, and could do the EGR, transmission fluid, etc, that you all trust. I am leaving to drive to NY again for the summer, and want to do a few things before I drive 2000 miles alone in one go!
    The car still gets 42mpg each tank, burns no oil (still looks perfectly clean btwn oil changes) and since I'm in WY, there's no rust (we don't salt roads).
    Any tips, suggestions, thoughts?
    p.s. i could do the transmission drain and refill, but the car needs to be up and level, and I don't have the jacks and ramps to do that in my driveway. the Toyota ATF is $80, and the Toyota dealer (conveniently walking distance to my house) charges $200 to do it, so I might let them do it.
  2. Mendel Leisk
    42,080
    Do you have a level, concrete slab? Sheltered, say at least a carport?
  3. bisco
    52,578
    any decent shop can do it if they are willing. or you could google hybrid or Toyota specialists
    Wyomingirl likes this.
  4. Wyomingirl
    Wyoming
    2014 Prius v wagon
    Not sheltered, but I have a big driveway. It's got a mild slope, but if I park lengthwise across it, it's flat at the top (near the garage --which is my woodshop--so no room for the car inside).
  5. PTS
    PTS Member
    95
    44
    Austin, Texas
    2013 Prius v wagon
    Egr cooler removal is a tough job and is likely clean. I would ask the shop that changed your engine if they used the 55k mile egr system.
    Odds are they did since it would have been much easier for them. If so you only have 65k on it with an engine that is not burning oil. Don't worry about it if that's the case.
    You would be better off changing the oil every 5k miles and the coolant every 50k. Your coolant should be good with an engine swap 10k ago.
    Wyomingirl and Air_Boss like this.
  6. Mendel Leisk
    42,080
    If you run the front up on ramps and securely chock the rear wheels you’d be ready for any eventuality in the course of EGR cleaning (say a dropped tool or fastener).
    It’s not that hard. The intake manifold and pipe between IM and the EGR valve is relatively easy and can be done separately. Or you can start with that, and depending on condition decide if you want to go further, pull wipers and cowl, extract the EGR valve and cooler.
    Second time around for me it was mostly done on a Saturday, wrapped up Sunday morning.
    see the EGR links in my signature (on a phone turn it landscape to see signatures), and also this workflow.
    #6 Mendel Leisk, Apr 24, 2026
  7. rjparker
    10,742
    6,740
    Toyota, dealers and most pro Toyota mechanics think egr cleaning hysteria is unproven and unnecessary unless it codes. There is no recommended maintenance.
    Many diy have taken the two days or more for a job that was not necessary. Almost everyone of the first timer diyers found it very difficult with poor access.
    My 2012 v has had two egr cleanings; one at 175k miles and one at 300k miles when I replaced the egr valve for an updated version. The cooler was free flowing the second time.
    If the vehicle has cold start shudders, there is an easy way to see if the egr valve is allowing flow when it should be blocking flow, the most common but still relatively rare egr problem on these cars.
    No cost egr block flow test
  8. Mendel Leisk
    42,080
    Count me in for hysteria. Prior to doing the EGR the most ambitious maintenance I'd done was fluid changes, brakes, spark plugs. Not saying it's easy as pie, but...
    (2022 Halloween pumpkins)
    #8 Mendel Leisk, Apr 24, 2026
    Wyomingirl and bisco like this.
  9. rjparker
    10,742
    6,740
    Even Mendel will admit to leaving off mounting studs to make reinstallation and subsequent "cleanings" much easier.
    Prius gen3 egr stud removal.jpeg Some have cut off brackets, some drop gaskets and reinstall the egr cooler or valve without a gasket only to CAUSE a rough idle they did not have before. No problem, just do it again.
    Frankly if changing the transaxle oil is something you would rather have the dealer to do, egr cooler removals should be carefully considered before jumping in.
  10. Mendel Leisk
    42,080
    Why do I feel like half those words are loaded, lol.
    Anyway, why not leave both the stud and nut off? It expedites removal big time, by:
    1. no longer needing to deal with it, access being difficult
    2. negates the need to remove the rearmost studs (at connection to exhaust manifold) which in turn means the gasket at that connection is retained by the studs when you pull the cooler forward and out.
    Not mentioned in your cut-and-paste of my previous posting, but an E6 socket is needed to back the stud out. And some wrestling cables and brackets out of the way. I used a diminutive 1/4" ratchet, and it took maybe 15 sweaty minutes, one stubborn click at a time, to get the damn thing out.
  11. Wyomingirl
    Wyoming
    2014 Prius v wagon
    Yup--they kept the EGR on that 2015 engine they swapped in, so that all has 65k miles on it, and it's running great.
    I just changed my email oil on Friday (the shop that did the swap in NY asked to change the oil early before I drove back to WY last fall, just to check the engine and check the state of the oil--and everything looked good to them). It looked pretty clean, wasn't low at all, and had nothing suspicious (metal, froth, etc). Sounds like I have a time to think about jumping into the EGR or not down the road (quite literally).
  12. Wyomingirl
    Wyoming
    2014 Prius v wagon
    I would help out on that Pie!
    I do my brakes, and spark plugs (which Thanks, Prius--couldn't make a simple job harder could you--with that wiper cowl? seriously) and oil and such. I'd likely be up for the EGR, next time I have 3 weekends free (Mendel takes a full weekend, so my dad always said multiple your time estimate by 3 and 1/2 the time you'll be quicker, and 1/2 the time something else will come up and it will take longer. He's rarely been wrong). I wish I had a shop for car things--that makes it harder where I live now. I was more confident in doing these things when I was near home and could use my dad's shop (and every tool I could imagine, plus a spare car for driving to get more parts).
  13. Wyomingirl
    Wyoming
    2014 Prius v wagon
    That's just the engine coolant, right? During the engine swap they'd not touch the coolant for the Inverter would they?
    Both tanks have perfectly translucent, pink coolant that I used be bulb tester and it pegged out as good.
  14. Wyomingirl
    Wyoming
    2014 Prius v wagon
    I'd do that transmission fluid if I had a good way to work under the car and keep it level. I'm pretty handy and I do love learning things and working on cars. That said, I took it to Toyota and they started to do the ATF. They said the drain bolt was a bit rounded so they ordered a new one and I'm waiting on that to come in first. In the mean time, I did my oil change, and looked at those plugs. I was esp curious b/c I know 100% that nobody has ever touched the transmission plugs so it was their tech that bungled it up. Sure enough, looks like the tech didn't fully seat that allen bit in the plug, and there's fresh, shiny rounded off parts of that plug b/c the Allen Bit was only about 1/2 way into the plug. So even though it's not hard to access I'm going to let them finish stripping the plug out when they change the ATF. I've stripped plenty of my own bolts!
  15. Wyomingirl
    Wyoming
    2014 Prius v wagon
    Been there so many times with other projects. When I get impatient I recall a story my dad told me. He was a lowly cartographer for Getty oil back in the 70's but when one of the big wig getty guys came back from a trip to study the African oil reserves he shared a story:
    They were driving in the middle of NO where, and came across a fellow rolling a tire down the road. Asked if he wanted a lift, and picked him up to take him to the next town (like--50 miles away). Got the tire repaired and the BigWig offered to take him back to the broken down truck to make sure he got back up and running--it is the middle of the desert, after all. They get to the truck and see that it's on 3 wheels and where the 4th tire was is all dug out (no way to jack and prop it up), but partially filled back in with sand. So they use the jack from the BigWig's truck and get it lifted and go to put the wheel back on and the BigWig asks where the Lug wrench is, and the poor fellow says he doesn't have one. The BigWig is shocked and goes to get his from the back of his truck for him. And then asks the fellow how he got the wheel off in the first place. The reply 'slowly, with many taps from a little stone he had found." So when some project seems hard, I just tell myself, "very small stones" and it doesn't seem so bad.
  16. rjparker
    10,742
    6,740
    On a v the inverter coolant goes to the radiator, inverter, inverter pump and transaxle. I would ask your shop.
    #16 rjparker, Apr 28, 2026
  17. ChapmanF
    18,773
    If you don't mind moving to the UK or Japan and getting the Prius that's configured for driving on the left side of the road, you can do the spark plugs without removing the cowl. It's the big double-jointed passenger-side wiper linkage in the US that makes the cowl be in the way of the coils.
