2005 prius engine oil overfill
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by John Skyline, Mar 23, 2026.
  1. John Skyline
    John Skyline Junior Member
    Asia
    Hi all, i have a 2005 gen 2 prius which recently did a engine oil change. I saw the mechanic poured the entire 4 litres bottle of totachi 5w-30 engine oil and I felt something was wrong. When i arrived home, i checked the dip stick reading and it was around 2cm above full mark. I've searched for existing thread but some said there were severe problems and had to change the ICE, and some said no issues. Car is driven in a southeast asia country, can someone advise what i should do now? Really worried because it's my daily workhorse. Car is originally from the US, have been driven for 8 years in southeast asia with no major engine problems/change. Thanks in advance.
  2. Tombukt2
    13,541
    2,439
    Just use your jackrabbit pump and stick it down the dipstick tube and pump out till true full . Done . If the car is using oil it should go down well quick.
  3. PriusCamper
    PriusCamper Senior Member
    13,155
    5,322
    Pacific Northwest, USA
    How many miles on the car? If its high miles and burns a quart every couple thousand miles or less no need to worry about it as it will take care of itself. But if it doesn't use Tom's method, or take it back and ask mechanic to fix it.
  4. bisco
    52,465
    I wouldn’t worry about 2cm
  5. pasadena_commut
    pasadena_commut Senior Member
    2,910
    877
    Southern California
    Two cm (not mm, right?) above the top mark is fairly high.
    It is 4 cm between the two dots on the stick and that corresponds to a change 1.5 or 1.6 qt, with 3.9 qt (3.7 liters) total in the system at the top dot. If everything was linear above the dots (not a safe assumption) that extra 2 cm would be ~.8 qt (.75 l) high. That is even more than expected from the observed overfill from the bottle, suggesting that the car wasn't drained fully or it was not read correctly.
    Did the mechanic not change the oil filter? The extra .4 l (or so) remaining in there might explain why it is roughly twice as far past the top dot as expected. Doing a rushed change (not waiting for the oil to stop dripping out) would also raise the final level.
    Was the level checked after the car had sat overnight on level ground or was it immediately after being driven? Oil splashes up the tube when the car is in motion, and brand new oil is difficult to read accurately. I suggest the OP read it again after the car has cooled off overnight.
    If that was my car and it was really 2 cm too high I would get some of that oil out.
    PriusCamper likes this.
  6. John Skyline
    Asia
    i am pretty sure it was 2 cm. Yes, i watched the mechanic change oil filter. And the dip stick was checked after sat overnight on level ground.
    Update: i just got back from a 650 km (400 miles) trip. Dipstick shows slightly 1 cm above the top dot. So far, there has been no changes in the driving experience. Surprisingly, the car does not jerk as much as before (when the car starts and fuel engine kicks in).
    Should i still pump some oil out?
  7. John Skyline
    Asia
    Mileage is close to 170,000 miles. Given the age of the car, i'm guessing the car might have already gone a full round (> 299,999 miles odometer cap) ?
  8. bisco
    52,465
  9. Mendel Leisk
    41,983
    Get the mechanic to drain the overfill?
    Being a little obsessive, I’d probably remedy it myself, by almost removing drain bolt, carefully draining about 500 cc. It’s not easy though, drawing it out with a vacuum device and a thin tube down the dipstick guide pipe is easier/safer.
    #9 Mendel Leisk, Apr 24, 2026 at 10:19 AM
  10. rjparker
    10,621
    6,657
    I probably would have vacuumed it out when it was 2 cm high (almost an inch high).
    But if it used 1 cm on the dipstick (almost a half an inch) in 400 miles you most likely have an oil burner. Another 400 miles and it will be at the full line.
    Sounds like the real problem is keeping it full between oil changes. Leave it alone.
    Normally I see 2-3mm overfills (about 0.1")
    #10 rjparker, Apr 24, 2026 at 10:44 AM
