Water Dripping Under The Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Meme Mymy, Apr 26, 2026.
Tags:
  1. Meme Mymy
    Meme Mymy New Member
    Israel
    Hello
    I have a 2012 Prius. Yesterday I started noticing water under the vehicle. I need help.
    I'm attaching a video for clarification.
    Please help.
  2. Mendel Leisk
    42,150
    Could be the air conditioning system's water condensation drain. That's normal.
  3. rjparker
    10,841
    6,808
    AC condensate is front passenger's side and is water.
    There is a potential for engine coolant in the same area but is normally pink and a little slimy.
    If it is coolant, the reservoir on the passenger side viewed from the top may go down. If that is the case, immediate attention is needed.
    Since the reservoir is somewhat opaque, a strong flashlight is best for observing coolant level.
    Shown at normal level
  4. PriusCamper
    PriusCamper Senior Member
    13,316
    5,390
    Pacific Northwest, USA
    It's probably the politics of the country you live in... Hell on earth and endless inhumanity and cruelty is too hot for a vehicle cooling system, which probably failed, just like what happens to nations that lose their military funding for genociding too much.
  5. rjparker
    10,841
    6,808
    Vehicle overheats because Israel does not know when enough is enough? A bit of a stretch.
    CR94 likes this.
