2005 Prius – “Check connection to air conditioner” + can’t locate A/C amplifier (HVAC ECU)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Gary Chan, Apr 27, 2026.
  1. Gary Chan
    Gary Chan New Member
    Chicago
    I’m working on a 2005 Prius and getting the “Check connection to air conditioner” message on the MFD.
    Here’s what I’ve done so far:
    Checked all relevant fuses (A/C, ECU, HTR) – all appear good
    Removed the MFD and reflowed/soldered pin 60. This was shown on a youtube video on a Lexus LS430 2004.
    I also tested ground brown wire appears stable coming into MFD. The green wire to pin 60 appears to be data and carries no voltage. So, I'm not sure how to test it.
    Removed the radio/head unit to inspect wiring and look for the A/C amplifier (HVAC control ECU). Chat GPT said this is the next thing to check/swap.
    At this point, I’m trying to locate the A/C amplifier, but I haven’t been able to find it.
    I’ve checked:
    Driver side near the gas pedal area
    Passenger side near the blower motor / HVAC box. Passenger side carpet towards center console. Center console appears to have a semi-circular duct box and behind the the hvac box? Im unable to remove the semi-circular duct.
    I’ve searched PriusChat and YouTube but keep finding conflicting info or unclear locations. For example, there is a video showing the ac amplifier near gas pedal, or blower motor under glove box or on the passenger door foot area. But not clear for the 2nd Gen Prius.
    Main question:
    Where exactly is the A/C amplifier located on a 2005 Prius (Gen 2)? Is it buried deeper behind the dash or mounted somewhere less obvious?
    Also, if anyone has run into this specific MFD message before, I’d appreciate any guidance on what else to check.
    Thanks in advance.
  2. dolj
    dolj Senior Member
    8,635
    4,389
    Wellington, New Zealand
    So, you're chasing this down because of a message on the MDF, yes?
    The next step, then, is to read the codes your car has. You don't have a capable reader**? Don't worry, read your A/C codes by following the instructions >> here << on our blink code wiki.
    Tell us the blink codes or the diagnostic trouble codes (DTCs) you have pulled from the car. We can then give you much better advice than ChatGPT.
    You don't have a capable code reader? If it is your plan to repair your own car, then you need to have a reliable way of reading your DTCs. Read >> this post << which sums up the review thread to that point. Feel free to read the whole thread that starts >> HERE <<.
    The only reference I found in the repair manual that said anything similar to the phrase you quoted above is contained in the work-up for DTC B1262 – A/C ECU Communication Stop. Other references are in:
    • DTC – P3108-535 –A/C Amplifier Communication Circuit Malfunction
    • DTC – P3108-536 – A/C Amplifier Communication Circuit Malfunction
    • DTC – P3108-538 – A/C Amplifier Communication Circuit Malfunction
    You are aware that ChatGPT does not know everything, and when it comes up against such knowledge deficits, it just makes stuff up. It is far better to access the correct information directly from the Toyota Prius repair manual for your car. The most up-to-date information can be obtained at Toyota TIS (Technical Information System). You can read all about how to do that in this >> PC wiki article <<.
    If ChatGPT has not led you up the garden path, you can find the A/C amplifier ECU in the diagram below:
    Location of A:C Amplifier ECU.png
    ** If you tried to read the codes and your reader reported no codes found, you do not have a Prius-capable reader.
  3. Gary Chan
    Chicago
    Thank you for your lengthy reply.
    1. I tried the ac auto and refresh/circ button press simultaneously while press Power 2x. No code appearing on MFD.
    2. New Discovery: ac auto turns on air and circ refresh opens the blender door actuators as I hear a click sound. This more likely rules out a problem with ac amplifier.
    3. Ac amplifier image. I removed the center console and I see a semi circular duct that I cannot remove and a box above that which appears about 6-8 inches wide much wider than the ac amplifier. But anyhow, i think the direction of problem is towards the MFD panel at this time.
    4. If I flash the OBD pins, will it give me the ac trouble codes?
  4. dolj
    dolj Senior Member
    8,635
    4,389
    So you followed these steps precisely?
    • Start with the car off.
    • Hold down both the A/C AUTO and FRESH/RECIRC buttons (on the steering wheel), while
    • turning the car to IG-ON (two power button presses, with no foot on brake).
    You saw no 2-digit code on the top right of the MFD? Not even 21?
    What do you mean by 'flash the OBD pins'? If you mean shorting CG →TC, then no, that is why there is the other procedure to capture the A/C codes.
  5. mr_guy_mann
    mr_guy_mann Senior Member
    4,111
    2,011
    NJ-USA
    Hmmm. The error message suggests that the MFD has lost communication with the HVAC system. Just a guess, but I don't think that the self diagnostics will work when there is a (MFD to AC) comm fault.
    Back to reccommending a capable scantool to see if the HVAC has any communication at all.
    #5 mr_guy_mann, May 2, 2026
  6. Gary Chan
    Chicago
    Just ran toyota tech stream software.
    Air conditioner diagnostic codes are:
    B1412 ambient temperature sensor circuit.
    Summary: no Malfunction now.
    B1441 air mix damper control servomotor circuit (passenger side) Summary: no Malfunction now.
    B1442 air inlet damper control servomotor. Summary: no Malfunction now.
    I will plug the MFD panel back in and see if any more codes come up. But currently no codes relating to the MFD.
    I just plugged in the MFD which reads: check the connection of the air conditioner
    When I press the climate button.
    I can press the ac auto button on steering wheel and the down arrow makes the air blow high speed and cold air.
    That makes a wiring issue or MFD panel itself a problem more likely.
    #6 Gary Chan, May 16, 2026
  7. Gary Chan
    Chicago
    My mfd panel suddenly appears to operate normally now. I believe that its due to increase temperature and less humidity. Although I do not know where the wiring is being affected.
