First engine light on my 2015 Prius V
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by ivanhoe, Apr 28, 2026.
  1. ivanhoe
    ivanhoe Member
    71
    28
    2015 Prius v wagon
    Hi everyone, got my first engine light! I used my Veepeak scanner for the first time and downloaded a app for the phone. I received the following codes P0015(93), P0123, P0301 and P1693. What am I looking at here, possible throttle cleaning in the works.
    Thx
  2. Mendel Leisk
    42,202
    Google search for P0015(93) mentions cam timing, timing chain. P0301 is for misfire cylinder one, which is VERY common with gen 3's and v's with head gasket failure.
    What's the miles and how long have you had it?
  3. rjparker
    10,888
    6,833
    I think I would clear the codes and see what comes back first.
  4. ivanhoe
    ivanhoe Member
    71
    28
    2015 Prius v wagon
    Mileage is at 196k km, I bought it in 2021. I've added a oil catcher to help with the cylinder 1 common problems.
    I could clear the codes to see what happens.
  5. ivanhoe
    ivanhoe Member
    71
    28
    2015 Prius v wagon
    Cleared the codes, got a code for high voltage for oxygen sensor. No P301, coolant level is holding at full!
  6. ChapmanF
    18,895
    Always better to tell us the actual code rather than a description. Easy to look up the right code and get the details. Harder working backward.
  7. ivanhoe
    ivanhoe Member
    71
    28
    2015 Prius v wagon
    P0138 and P0607
