1. detelindetchev
    detelindetchev New Member
    NC
    Guys is there free REPAIR MANUAL online? Thanks.:rockon:
  2. jdenenberg
    jdenenberg EE Professor
    3,957
    1,955
    Trumbull, CT
    2020 Prius
    LE AWD-e
  3. krg03
    krg03 Not expert, just experienced
    246
    31
    so cal
  4. John Holmess
    John Holmess New Member
    Alaska
    You might find some free resources online (like wiring diagrams or partial manuals), but full versions are usually paid or require subscription access.
    If you’re planning to do your own work, your best bet is to get proper toyota Repair manuals(dot)com(PDF). They give you complete repair steps, diagrams, and specs so you’re not stuck relying on the dealership for everything.
  5. dolj
    dolj Senior Member
    8,601
    4,364
    Wellington, New Zealand
    Presuming that you remove the spaces and replace (dot) with a period, that link resolves to a dodgy looking Indonesian gambling site. Best edit this post to remove that link.
  6. dolj
    dolj Senior Member
    8,601
    4,364
    Looking at the links in the other post, they both report that the sites are not secure. Maybe these should be reviewed by @jdenenberg and @krg03?
  7. jdenenberg
    3,957
    1,955
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My web site, doctord.webhop.net, is not "secured" as I do not do any financial transactions. It is reported correctly as "Not Secure" by the web browser, but there are no files with viruses on the site.
    JeffD
  8. ChapmanF
    18,661
    Is that just a matter of not having https set up for the site?
    Web browsers are getting more and more aggressive about 'protecting' their users from non-https sites, so increasingly visitors to a no-https site have to jump through more and more hoops to get the site to display.
    20-plus years ago when I first set my site up, my provider would have charged extra for SSL, so I didn't bother,
    Since more like ten years ago, they don't charge extra; in fact, around the time I was getting around to asking them, I tried out my site with https in front and it worked. :) They had just added SSL for me before I even asked. They use Let's Encrypt for free certificates. It's very little burden to support SSL these days.
  9. jdenenberg
    3,957
    1,955
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I run my web site locally in my basement so I am the provider using the free Apache server on a Windows PC. So far I have not needed to run SSL thus the "Not Secured" notice.
    JeffD
  10. Mendel Leisk
    42,014
    OP's been here since 2010, and this was his first post, nothing since. I messaged him a link to my copy.
  11. Seraphim
    Seraphim New Member
    Michigan
    There is a certain assembly of "lemon"-flavored "manuals" that cover a lot of makes/models/years. ;)
  12. dolj
    dolj Senior Member
    8,601
    4,364
    Maybe it’s just me, but that one’s a little too cryptic. Do you mean a manual archive or a Haynes/Chilton-type source? In any case, being a bit more explicit about which manual source or archive you mean would probably help more people.
