Free 2009 Prius
Discussion in 'Prius Cars For Sale' started by Qdog, Apr 19, 2026.
  1. Qdog
    Qdog Junior Member
    Michigan
    2020 Prius Prime
    Selling for free.. :)
    2009 Prius 290,000 miles - Will not run , replaced HI Voltage battery 1.5 years ago with refurbished battery..
    Water Leaking in causes shorting everywhere.. Tried to fix 2 times to stop water (rainfall) from getting in.
    We live in SW Michigan, north of South Bend IN.. 2 hours from Chicago, 2.5 hours from Detroit.
    Ran good, has original Cat Converter, never changed brakes in ownership from 40,000 miles in 2011.
    If no one takes it, I will try to get junk Hauler to take it
    52,672
    the cat is likely worth good money, call some metal recyclers. all the best!
    Air_Boss likes this.
  3. Rmay635703
    Rmay635703 Senior Member
    2,684
    1,721
    Somewhere in Wisconsin
    2013 Chevy Volt
    IMG_8786.jpeg I wish others were as generous as you
  4. penelhum
    penelhum Junior Member
    northeast
    I wish you were closer to me. Good luck
