Gen 5 Prius ride comfort and cabin noise – improvements?
Discussion in 'Gen 5 Prius Main Forum' started by andentalbania, Jan 25, 2026.
  1. andentalbania
    andentalbania New Member
    Italy
    Limited AWD-e
    For those who have driven both Gen 4 and Gen 5, how noticeable are the improvements in ride comfort and cabin noise? Toyota mentioned chassis and suspension updates—do they actually translate into a quieter or smoother daily drive?
  2. Paul Gregory
    Paul Gregory Senior Member
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I am recovering from a broken back that happened over a month ago. I don't feel any comfort in my ride. In fact, it hurts every time I drive over a bump.
    PriusCamper likes this.
  3. VelvetFoot
    VelvetFoot Senior Member
    1,408
    545
    New York State
    2026 Prius
  4. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I'm not sure if it's caused by the cold temperatures on the shock absorbers. But quality shock absorbers should work well in cold temperatures.
    futurist likes this.
  5. PriusCamper
    PriusCamper Senior Member
    13,455
    5,430
    Pacific Northwest, USA
    Get well soon! Put everything you got into your physical therapy schedule so you get better! Most people don't realize that getting healthy again versus a lifetime of debilitating chronic pain is mostly defined about hard they go with their PT discipline!
  6. futurist
    futurist Member
    57
    183
    United States
    2024 Prius
    Decent struts / shocks normally have bypass ports that permit oil flow around a damping shim stack, when temps go low and increase viscosity. However lots of OEM struts / shocks have only the most rudimentary damping to juuust satisfy engineering briefs.
    Off-road racing shocks can even tune for specific damping during bypass as well, to keep performance consistent despite ambient temps. But for most milquetoast, non-high-perf AWD dampers... colder means stiffer, at least until the oil warms to baseline temp (determined during design). Worn shocks can have damping oil even more viscous due to particulate clogging ports and increasing resistance to flow.
    I remember having to assemble Yamaha XVS650 V-Star 650 cruisers for the showroom of my dealership. They initially came with no damping oil in the front forks, in order to satisfy some regulation (which chg'd later)... so a big bottle of beer-coloured oil were strapped into the crate for tech to prep...
    The oil they used, was fish oil -- literally, waste fish oil of sufficient performance characteristics w/ certain additives, to become the de facto 650 V-Star's fork oil (at least during mfr). When some of these bikes came in years later for fork seals... holy HELL that organic oil was rancidified into a literal room-clearing bomb, as soon as that fork cap came off. Choking back heaves as I cleaned the parts, re-assembled w/ a synthetic oil and fresh seals and test-rode. 100% better ride vs. a new V-Star 650, exact same everything else.
    Yamaha got something that satisfied the ground floor of engineering brief but least-expensive... and it were effing fish oil. Not sure if that applies to car dampers... but given hugely greater volumes than motos don't see why they wouldn't, since customers would just chuck an old one & never break open an OEM shock or strut for repair :sick::p
    Trollbait likes this.
  7. jacklee95401
    jacklee95401 New Member
    San Francisco Bay Area
    2026 Prius Plug-in
    XSE
    just bought my 26 Prius PHEV last week and coming from a 2017 Lexus ES350. I think the Prius rides just fine, it sure ain't floaty like the ES. It is noisier in HEV mode, as expected. A little more Highway noise than the ES, again as expected. Both ES and new Prius are riding on Michelins.
  8. dicknose
    dicknose New Member
    Toronto
    2024 Prius Prime
    XSE Premium
    A big factor is the 19" rims on rubber band tires. I swapped these out for 16" wheels on 205/65r16 (standard Camry tire size) and the ride is MUCH improved.
    Regarding noise levels, XSE Premium trim (and I believe LTD) have laminated glass on the driver/passenger windows which is supposed to help reduce road noise.
