Are battery cells interchangeable?
Discussion in 'Gen 2 Prius Main Forum' started by GreaseMonkey123, Jun 3, 2024.
  1. GreaseMonkey123
    GreaseMonkey123 New Member
    Michigan
    I have a 2005 Prius with a couple of bad battery blocks, blocks 7 and 8. I found that I can buy remanufactured cells online, but I'm not sure if all 2nd Gen battery cells are interchangeable or if I need to buy sets of cells specifically for blocks 7 and 8. Thanks! :)
  2. Tombukt2
    13,869
    2,521
    By any of them you like how do you know and trust any of these sellers these are just people with stuff that went bad in the Prius and now they're disassembling it all throwing it into boxes thinking they can make a recovery of their mishap I mean let's be reasonable here If all of a sudden you couldn't buy Duracell batteries at the store for your flashlight what kind of nonsense would we partake in the next day or after we discovered we couldn't buy decel flashlight batteries anymore A lot of this kind of nonsense unfortunately. So if you can find somebody that's into these workable batteries that doesn't like for a hobby they're interested in forwarding their knowledge to go on to do I don't even know what but that's what my battery guy is He's a young guy he's into all this stuff gaming and segways and battery operated everything and all of that kind of thing fantasizes about this kind of stuff you know what I mean I don't have time for all that but he does really good work and he's built them a pretty cool setup. There are people like this all across the country bored millwrights who have nothing to do when they're not at work No wife to harang them to death about the disposal that sort of thing they're out there you just have to find them.
  3. bisco
    52,880
    yes, you can even use gen 3 and 4 (nimh) but if you can find new modules, you would be better off.
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,018
    NJ-USA
    So, the high voltage battery pack on a Gen2 (and most Gen3 and some Gen4) Prius is made up of 14 blocks connected in series. The battery ecu monitors the voltage of each block.
    A block is two modules (also in series). So 28 modules in the entire pack.
    Each sealed module is 6 x 1.2V NiMh cells, for 7.2V nominal. 7.2V times 28 modules is 201.6V total, but actual voltage can go over 215V. All the modules in a pack are "the same" (interchangeable).
    "Just" replacing failed modules on an old pack can work - you can find used or "refurbished" ones all over the web. The problem is that most of the time, the replacement modules have different effective capacity or state of charge. That means that the voltage under load as measured by the battery ecu is too different from other blocks - so the ecu sets codes.
    Battery modules degrade with time and use. Up to a point that's not much of a problem so long as they degrade evenly. They will still perform evenly. Get some "other" modules and you have a very small chance that they will be close enough to not have problems.
    There's many days of reading in the posts here about module replacement.
    The only source for genuine new modules is to buy a full set from Toyota.
    Brian1954 likes this.
  5. Tombukt2
    13,869
    2,521
    I still don't really understand why somebody at home or at an electronic shop or wherever the hell they are and they can get parts can't just build a 211 volt based battery would say I don't know 8,000 mAh we're double what the Toyota battery is I don't mind if it's a little taller I'll work all that out after they hand me the 140 lb pack versus the 80 I took out doesn't seem like it would be that huge of an undertaking I don't necessarily need it to be lithium necessarily but something but I guess there's something that I don't know electrically that's just fine I know other individuals have built batteries and done some different things like the guy has in the car in Maryland that can be plugged up and charged which that's not my end game here because I think the generation 2 would be limited in speed and all of that stuff no matter how much you plug the inner charged it and that's not really what I'm looking for to drive off battery per se. Just a little more MAH I guess. But I guess it really doesn't matter in central Carolina we're not taxing the cars here and we're not mountain traveling or any of that stuff trying to break record speeds or anything so it's all good like the advertising and reviews have said for the last 20 years the Prius is a low power alternative that does everything very very well and that's that road and track car and driver all of them I've said the same thing basically.
  6. Classic Car Guy
    Classic Car Guy Active Member
    506
    136
    Northwest, USA
    Hi,I have a question on the prius hybrid battery when its balanced to 7.75 volts. When i put the hybrid pack together with 7.75 volts per module will the engine "or" the dynamo that cranks the engine will it start with that voltage? Thanks
  7. Tombukt2
    13,869
    2,521
    Pretty much yesir.
    Classic Car Guy likes this.
  8. Classic Car Guy
    506
    136
    Northwest, USA
  9. Tombukt2
    13,869
    2,521
    When you rack everything up and apply the nuts in the bus bars in the orange wires correctly you should measure around 200 to 211 V or so . I think I've cranked started a gen2 w 165V before. Soon as the car started and got running I put it in gear and floored the brake and greened it up before I started driving to much . Car still sitting right here working almost daily.
  10. Brian1954
    Brian1954 Senior Member
    2,693
    1,076
    South Central PA, USA
    28 battery modules at 7.75 volts connected in series adds up to 217 volts. That is more than enough to power the electric motor to crank the engine.
    Whether you car will go into Ready so that the engine can be cranked over is a whole different question.
    #10 Brian1954, Apr 30, 2026
  11. priuslyfe
    priuslyfe Member
    349
    71
    I don't know for sure but I watched a video and had the same question...asked AI
    Yes, all 28 modules in a Gen 2 Prius hybrid battery are physically the same.Key Points:
    • Identical design: Every module is a 7.2V NiMH unit containing 6 cylindrical cells wired in series. They are interchangeable in terms of shape, size, mounting points (including the bottom threaded holes), and terminal layout.
    • Orientation alternates when installed: Modules are flipped alternately (one right-side up, next upside down) so the positive and negative terminals line up correctly for series connection with bus bars. This is why end modules look slightly different in photos — it's just how they're rotated.
    • Mounting holes: All modules have the same bottom mounting points (2 threaded holes per end).
  12. ChapmanF
    19,045
    AI probably confused what it read about the original modules and some aftermarket cylindrical-cell retrofits. :)
    Nobody but a mathematician would call the cells in the original modules "cylindrical cells", because that term is more reserved for individual cells built as round metal cans like flashlight batteries. Some vendors have sold replacement Prius batteries using sticks of those wired in series.
    Now, if there were a mathematician in the room, that person would say "sure, the cells in the original module are cylindrical—they're right rectangular cylinders, standing vertically, all enclosed in the plastic module."
    The mathematician would then probably duck and leave the room.
    priuslyfe likes this.
  13. pasadena_commut
    pasadena_commut Senior Member
    3,069
    956
    Southern California
    The battery modules have prismatic cells. These differ in substantial and important ways from cylindrical cells.
    Battery University | BU-301a: Types of Battery Cells
    Oddly many sources claim that prismatic cells have a lower cycle life than cylindrical, which is exactly the opposite of what has been observed in Prius packs vs. Honda packs for NiMH. Perhaps it holds for other battery chemistries?
  14. ChapmanF
    19,045
    To battery folks, 'prismatic' and 'cylindrical' are the names of specific different ways of manufacturing a cell.
    To math folks, a 'prism' is just any cylinder whose base is a polygon (such as a rectangle), so the shape of the cells in these modules could just as well be called a right rectangular prism or a right rectangular cylinder.
    That's why, to math folks, a "cylindrical" cell might not be "prismatic", but any "prismatic" cell is still "cylindrical".
    Naturally, the big practical differences between the two cell designs have to do with the meanings the battery folks use, not the ones the math folks use.
  15. pasadena_commut
    3,069
    956
    Southern California
    Isn't it the other way around? A prism is two copies of a polygon, located in different but parallel planes, with no rotation, with the matching vertices connected by line segments. The cylinder is a prism whose base "polygon" has infinitely many sides and a constant radius, that is, a circle. That would be a fairly modern (only a couple of hundred years old) definition. Euclid defined a cylinder as a rectangle rotated around one of its sides, so that that side became the center of the cylinder. Euclid's method cannot make an oblique or elliptical cylinder, whereas the more modern "derived from a prism" method can do so easily.
  16. ChapmanF
    19,045
    That's a description of a circular cylinder. Which is the only kind Euclid had in mind, but that was a long time ago.
    There are two ways you can think of making a circular cylinder: by taking a rectangle and rotating it, or by taking the base and sliding it.
    The first way, though—Euclid's way—can only make a circular cylinder. The second way can make a cylinder from whatever base shape you want.
    If you make it from a polygonal base, you can also call it a prism if you like.
    If you make it from any other closed curve as a base, not a polygon, you don't get to call it a prism.
    So, the cylinder : prism relationship is general : specific.
    There's no prism : circular cylinder relationship in the general : specific sense, but there is one in the finite : limit case sense, as the number of polygon sides ⟶ ∞.
