Potentially damaged SAS and seeking feedback on errors
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by nayrrr, Apr 26, 2026 at 11:05 PM.
  1. nayrrr
    nayrrr New Member
    Saturday
    US
    2024 Prius
    I think I have a damaged steering angle sensor on a gen 5 non-plug in. There are multiple error lights and text errors on the dash - see the attached picture for the lights and the text errors are typed out below. The car was likely driven with these errors for about 3-4 mins up to ~38mph, going through multiple braking cycles where a loud noise can be heard. Could it just be engine brake assistance given the low braking power? I've attached a clip of the noise - had to zip it to upload. I'd appreciate any insight on if braking in this state will have caused damage to other components (brake actuators, rotors, calipers, etc.).
    Text errors on car start:
    • Braking power low
    • Brake override malfunction
    • Secondary collision brake system malfunction
    • Check engine (I'm assuming this is related to all the warning lights on the dash)
  2. VelvetFoot
    VelvetFoot Senior Member
    1,314
    513
    New York State
    2026 Prius
    Why SAS, and not brake system.
    Sounds like some kind of brake noise.
    I'd check the codes.
    Barring that, it's a safety thing-dealer is probably the only option.
  3. Mendel Leisk
    42,020
    With a 2024, would this be covered by warranty?
    to illustrate sound, maybe just upload to YouTube, post link.
