2012 Prius door lock actuator motor
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Alex4234, May 2, 2026.
  1. Alex4234
    Alex4234 New Member
    Michigan
    I have an issue where the passenger door lock will intermittently not work, and I found motors fairly cheap, does anyone know if these are the correct motors and if they’re the same for all 4 doors?
  2. PriusCamper
    PriusCamper Senior Member
    13,316
    5,389
    Pacific Northwest, USA
    While there is a known problem with Prius C door locks, I've never read of a problem on here with standard Prius... Can you explain your diagnostic method to determine the motor is the problem? As for buying the right part, because your car is 16 years old I'd recommend pulling the part as a complete assembly from a wrecked Prius to save time and hassle because just installing a motor you buy on the internet could have unforseen compatibility issues.
  3. Alex4234
    Alex4234 New Member
    Michigan
    When the door won't unlock, I notice that the lock knob jerks slightly which looks like a weak motor. its very intermittent, it doesn't work one minute and then it's back to working perfectly for a while.
  4. PriusCamper
    13,316
    5,389
    Hopefully a cleaning and inspection and more lubrication is all it needs... Or at least that's where I'd start.
