Brake fluid color
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ATlam, Jan 25, 2020.
  1. ATlam
    ATlam Member
    64
    57
    San jose
    I recently had an oil change at this shop and they recommended a brake fluid change based on the color of the oil. I took some pictures and it looks clear to me, are they trying to upsell me?
  2. elementnomore
    elementnomore Member
    136
    44
    Los Angeles
    What year is the car and mileage?
  3. Mendel Leisk
    42,112
    Toyota Canada policy now is to change it tri-yearly or 48K kms (30K miles), whichever comes first. I pay no attention to the color, just drain and replace two pints (one quart) tri-yearly. DIY it cost about $15 for the fluid.
    Excerpt from Toyota Canada 2014 Owner's Manual Supplement:
    Takes about an hour, plus the time to raise and level the car, get the wheels off. It "can" be done with the car on the ground, but if you're doing some sort of tire rotation (putting on snow tires in my case), just sync the fluid change with that event.
    If you're doing the "without techstream" method, just using basic tools, you'll need someone to push the brake pedal. Watch the @NutzAboutBolts video (pinned at top of 3rd gen maintenance forum), multiple times, and have a read through the attachment.
    My tools:
    Kirkland 1.9 liter mayo jar with lid, hole drilled in lid for tube
    About 18" of clear tubing
    Largish syringe with short length of tube and slim spigot at the end (for basting out reservoir
    Bleed bolt coupler gizmo (connect to tubing, and push onto bleed bolt)
    8 and 10 mm wrenches
    8 and 10 mm sockets and ratchet wrench (to do the initial partial break loose of the bleed bolts)
    Torque wrench (not critical
    Question #1, lol: how much is dealership asking for this? If around $100, I would go for it, it's overdue, cheap insurance. Do ask them to test drive after, and verify all bleed bolt caps are present, not lost. Repeat the exercise yourself too: make sure the brakes feel normal.
  4. ATlam
    ATlam Member
    64
    57
    San jose
    Sounds like I need to change it. It has been at least 5 years since I got the car and I have put in at least 85k miles to it. (I'm just paranoid of shop upselling)
    mikey_t likes this.
  5. Mendel Leisk
    42,112
    How much ($'s) did they ask for this? Or did the conversation not advance that far, lol.
    Up here it's $100~125 (CDN) these days. Should be around $100 in the States, at the most. Don't let them BS that's it super complicated on Prius. My wife and I managed this in about an hour. It's a little tricky, but no big deal.
    dig4dirt likes this.
  6. Leadfoot J. McCoalroller
    8,203
    7,707
    Pennsylvania
    2018 Prius c
    It does look dark, and 5 years is plenty long.
  7. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    No it needs to be changed dude it’s dirty
  8. dig4dirt
    dig4dirt MoonGlow
    1,153
    741
    Lancaster Co PA
    ehh, I would say a bit more than $100 is fair game, but walk away if over $175
  9. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    If it’s over 200 I would say something
  10. ATlam
    ATlam Member
    64
    57
    San jose
    Thank guys :) they did quote quite a bit but it includes some other stuff, I'll get it changed.
  11. Fostel
    Fostel Member
    96
    30
    Kent
    Excel
    Can I have more info about this, please?
    How much fluid do I need for a full change?
    I've done at least 50k miles and 4 years on mine.
    Thanks.
  12. Mendel Leisk
    42,112
    The couplers seem a little hard to find on their own. Could be I don't have the correct term. It's basically a rubber bit that pushes onto your drain tube, with a ball joint type socket you can push onto the bleed bolt tip. An example:
    Regarding volume of fluid to be replaced: it would be REALLY nice if Toyota would publish this info. I've gone with 2 pints (1 quart), but I did just hazard a guess. IIRC dealership did 4 pints (invoice says "4 units", when they did a change one time, during a brake recall campaign).
    2 pints seems pretty good to me, allows an initial baste-and-fill of reservoir, and a goodly amount bled out at each corner (more at rears than fronts) and an ounce or two held in reserve, in case you want to fine tune the level in the next day or two (I've never needed too though).
    johnHRP and Fostel like this.
  13. Mendel Leisk
    42,112
    Here we go:
    Universal Brake Bleed Adapters | Mityvac | MVA6913
    This is what I have, came with my Mighty Vac kit. The only bits I've ever used lol. The little spigot is handy too, for siphoning out reservoir: there's a mesh basket in it that hinders getting a tube down. There's a narrow slit in that basket that the skinny spigot can reach through (pushed onto a tube connected to a syringe).
    Fostel likes this.
  14. johnHRP
    johnHRP Active Member
    646
    189
    KA, DE
    Excel
    Get $5 brake fluid tester. That's stupid cheap plastic voltmeter type is actually really accurate in 1% accuracy. Colors is not a good parameter, some brake fluid is dark or yellowish color even when it is new. It is not a good parameter. We should use a strip tester if you want to check the anticorrosion level, but it is cheaper just to replace the brake fluid on the reservoir with a turkey buster or anything to suck it.
    tangerino and GrGramps like this.
  15. eliteconcept
    eliteconcept 700 mile club, top tank mpg 69.5
    449
    186
    Indiana
    2022 Prius Prime
    didn't see it mentioned here. but keep in mind that brake fluid doesn't really "flow" within the system. The stuff in the reservoir doesn't constantly flow back and forth to and from the calipers. Not that its stagnate, but its not like coolant that constantly flows. So if the stuff in the reservoir is darker in color, the stuff at the calipers is likely much worse. Depending on your climate and how hard you brake, somewhere between 2 and 4 years (mileage is less of a concern) is likely appropriate without feeling too soon or too late.
    #15 eliteconcept, Apr 22, 2021
  16. Mendel Leisk
    42,112
    Yup, and basting out and refilling reservoir (mentioned up the page) isn’t that effective.
  17. Gloria&Suzanne
    Gloria&Suzanne New Member
    Sacramento, CA
    That needs replacing, not urgently but definitely needs replacing. New dot 3 brake fluid is supposed to be light yellow.
  18. johnHRP
    646
    189
    KA, DE
    Excel
    This is partly true. However, everything in such a liquid hydraulic system diffuses over time. My friend did a caliper rebuild job on his gen 3 hybrid, and the reddish silicon grease he used to rebuild the calipers made his brake fluid reddish for almost 2 brake fluid flushes/6 years.
    I also just replaced my friend's Opel Astra K rear brake. Accidentally, we pop out the left rear brake piston because I thought it turned to the left to press the calipers. It was already late, and I had to put them back relatively quickly, so I cleaned the calipers and sprayed them a couple times with brake cleaner to remove all junk and dust that got in. He went home safely; a week later he came back to ensure everything is fine.
    I found the brake fluid is murky with some kind of cloudy spots. It must be from the dirt and brake cleaner residue that diffuse up to the reservoir. I flushed the brake fluid for 0.5 L, and everything looks fine, no dirt, but the brake fluid in the reservoir kept having this residue.
  19. Mendel Leisk
    42,112
    a belated correction: the bottles of Toyota DOT3 that I got from dealership where 12 oz, not “pints” (16 oz, 1/2 qt). I used two 12 oz bottles for my brake fluid replacement.
    Our half-baked adoption of metric is no help. Anyway, 12 oz converts to 355 cubic centimetres (cc), roughly:
    12*29.574=354.888
  20. Paladain55
    Paladain55 Active Member
    413
    172
    The South
    My 2010 is still on the original brake fluid. Just low heat capacity of the fluid. Does this come into play on the prius? No. Its still just fine. I have put castrol srf in my fun car, and my tow hauler. Hot brake fluid is quite a cheat code for cars that are heavy on the brakes. But hybrids and evs rarely use the brakes to need the heat capacity from fresh brake fluid. Still have original front pads and rotors at 250k, rear setup went to like 180k.
