12V Battery Prius Prime Advance 2017 Model - replacement labor charge is $200
Discussion in 'Prime Main Forum (2017-2022)' started by Sid786, May 1, 2026 at 1:31 PM.
  1. Sid786
    Sid786 Active Member
    267
    148
    Cherry Hill, NJ
    Guys, Is there something special about the replacement of this 12V TrueStart battery replacement in Toyota Prius Prime. I have called multiple dealerships and they both are charging $200 to replace the battery, which cost about $215. So a total of $415+tax just to replace the battery.
    My battery died and I was getting the error message "Pre-Collision System Malfunction Visit your dealer". Called the AAA, which says that low cranking volt. Battery is 5 years old so it needs replacement for sure.
    I asked the AAA guys to just disconnect the Red cable on the battery and reconnect after the jump start and now the error message "Pre-Collision System Malfunction Visit your dealer" is gone. But got the message the ICS is unavailable, which is normal and requires driving for 10 or 15 minutes to go away.
    My key question is that can I just not replace the battery myself. Is there something Toyota dealers do something special to replace the battery.
  2. BiomedO1
    4,331
    2,275
    Left Coast
    I believe that battery is under the hood and easy to get to. Anyone can charge you what they want to do the job - unfortunately that's the sign of the times. You may want to check with your neighborhood Les Schwab or tire place - overall cost should be lower.
    Most places like Sam's Club, Costco, and some auto parts store, for the price of the battery; will do that for free, since it's easy to get to. Call around and don't get ripped off.
    Just my two cents......
  3. PriusCamper
    PriusCamper Senior Member
    13,182
    5,333
    Pacific Northwest, USA
    Criminal price gouging with Toyota Stealerships keeps getting worse or worse. Meanwhile most auto parts stores will install for free... But more importantly this is an opportunity for you to find a friend or family member to help/teach you how to do basic car repair stuff to save you a fortune in years to come. Or maybe someone on here lives near you?
    I prefer this 12v battery that only costs $118 and you use longer bolts and some washers and have been putting them in Priuses for 15 years: https://www.ebay.com/itm/141206981871
    Also this battery for $175 allows you to control the 12v with your phone and is the most advanced battery chemistry you can buy today: http://www.saltyhybrid.com/products/the-ultimate-12v-battery
  4. Sid786
    267
    148
    Cherry Hill, NJ
    Thank you for the response. Let me check around with AutoZone, Napa and Advanced Auto and see what they offer.
    Also note that I do had a AAA Premier membership and just learned today that Premier membership of AAA gives the battery completely free and also do the replacementsi.e., zero dollar. It is one battery per year replacement. The only issue is that AAA dont carry Prius Prime battery i.e., their battery wont fit the battery case. Although they do a load test before giving a free battery and my battery had low cranking volts so it did pass their replacement test.
  5. Mendel Leisk
    42,040
    Yeah a 12 volt battery replacement shouldn't cost more than $50 USD, even that's steep. It's 10 minutes work for a pro, at the most. Short version of the drill:
    Disconnect neg cable from battery
    Dsiconnect pos cable from battery
    Remove battery.
    Install new battery
    Connect pos cable to battery
    Connect neg cable to battery
    Additional good practices:
    Employ a memory saver, that maintains 12 volts supply during the swap
    Clean the cable clamps and new battery posts before install
    Maybe worthwhile, but not strictly necessary, assuming new battery is relatively fresh stock:
    Charge up the new battery before install
    Consider DIY?
  6. Sid786
    267
    148
    Cherry Hill, NJ
    DIY seems possible. Looks like someone has already posted a battery replacement video of the same 2017 Prius Prime model that I have:
  7. rjparker
    10,649
    6,681
    "Lets do the black one first, maybe" loosens it but leaves it connected.
    Wrong and dangerous.
    Always completely remove the black (negative) cable first. Then there is no chance of a big short from the positive to any metal via the wrench.
    When reinstalling, positive is tightened first and then negative, again to avoid a big short and even worse.
    BiomedO1 likes this.
  8. BiomedO1
    4,331
    2,275
    Left Coast
    Also spend a couple of extra bucks on a terminal cleaning brush and terminal sealing kit. Clean off the posts & connectors. Put that ring down, connect & tighten, then spray the sealer. You shouldn't have any connection or corrosion issues for the life of that battery.
    frodoz737 likes this.
  9. Sid786
    267
    148
    Cherry Hill, NJ
    Thanks for identifying this mistake in the video. ChatGPT says the following:
    Wrench / Socket Sizes
    • 10 mm → battery terminals (most important)
    • 10 mm → hold-down bracket bolts (usually)
    • 12 mm (occasionally) → bracket base or mounting bolts, depending on trim
    Battery Location
    • Open the hood
    • The 12V battery is located on the driver’s side (left side) of the engine bay
    • It’s typically covered with a plastic housing
    Safety Steps
    1. Power Down Completely
    • Car OFF, key fob away from vehicle
    2. Remove Battery Cover
    • Take off the plastic cover over the battery
    3. Disconnect Terminals
    • Negative (-) FIRST
    • Then Positive (+)
    4. Remove Hold-Down Bracket
    • Unbolt and set aside
    5. Swap the Battery
    • Lift out old battery
    • Place new one in same orientation
    6. Reconnect
    • Positive (+) FIRST
    • Negative (-) LAST
    7. Reassemble
    • Reinstall bracket and cover
  10. Mendel Leisk
    42,040
    One more thing: the battery hold-down system Toyota uses is absolutely inflexible regarding battery height. If the replacement battery's height varies by a mm or two, the bracket will be loose, or teetering. It's good to have a few washers and shim strips on hand, just in case.
  11. TinyTim
    TinyTim Active Member
    391
    238
    Seattle
    Before you get your next battery. I would invest in a battery reconditioner/charger that is at least a 12v 6amp output tender. If you juice your battery regularly. You may have more life in it. 5 years is not a long time for a Prius battery. The True Start Toyota battery comes with an 8 year warranty.
    When a battery is new. You do not need to run a charge cycle more than once every 2 or 3 months. The winter months I would put the 12V on a charger once a month. As the battery gets older, once a month charging cycles work best. You should also invest in a jump pack. That way you can jump start your own Prius.
    I recently had a low voltage issue with my Prius 12v. The computer started going crazy and reducing power to the entire car. It would not properly shut down. I put the car on a 12V 10amp 6amp charger for a minute or two. The car shutdown normally after that. I left it on the charger for 5-10 minutes. It started like normal. When I got home, I put it on the battery tender and everything has been good.
  12. Mendel Leisk
    42,040
    Whoa Nelly, Owners Manual advocates a ceiling of 5 amps IIRC.
    My moneys on round the clock. Our usage is sporadic; the car often sits as much as a week, punctuated by good workouts more often than not.
    I hook up a CTEK 4.3 amp smart charger the day after a drive, and it sits thus, till next use.
    current battery (gen 3) is an Optima Yellow Top, installed September of 2010. Tests like new.
  13. bisco
    52,521
    gen 4 is the easiest battery to replace
  14. TinyTim
    391
    238
    Seattle
    I have a 4amp battery tender/charger designed for leaving it on the battery for an extended period of time. My other is a battery charger/reconditioner rated up to 10amps. The real world charging usually starts at 9amps and goes down to 1 amp after an hour or two until full charged.
    I am not talking about the old school 10 amp straight chargers. Though they work and that is what mechanics still use today. The current newer generation chargers do a lot more and things are done differently in the charging cycle. I can assure you that if a mechanic charges your dead battery. They would use a 10amp or 20amp straight charger. That's how they have always done it.
    Remember, Toyota builds their cars with the assumption that their customers will not properly take care of it. Using a 10amp charger or even 20amp charger is not going to hurt your battery. Obviously you do not want to leave it on a charger more than 8 hours if you are doing straight 10-20amp charging.
  15. rjparker
    10,649
    6,681
    Correct any charger made in the last 20 years is fine. It would be ideal if it had an agm charging algorithm but is not necessary.
    Toyota's built in charger may supply 50 amps or more for short periods.
    Toyota does not want you to use an old school 70's unregulated charger rated at more than 4 amps.
    TinyTim likes this.
  16. Sid786
    267
    148
    Cherry Hill, NJ
    A few years back, when I was traveling for more than 30 days, I picked up a solar trickle charger—and it’s worked pretty well for keeping the battery maintained.
    I also invested in a jump starter, and that has been a lifesaver. It’s saved me at least twice already and spared me from waiting hours for AAA. I’m currently using the VTOMAN X7 Jump Starter with Air Compressor (4250A, 160 PSI, supports up to 10L gas / 10L diesel engines), and it’s been very reliable so far.
    One thing I learned the hard way with the trickle charger: it comes with a fuse that you can remove when the charger is not in use. If you leave it connected without removing the fuse, it can actually cause a small drain on the battery. Worth knowing if you’re planning to leave it hooked up long-term.
    Over the weekend, I did some research (with a bit of help from AI tools) and decided to go with the DieHard H4-XEV AGM battery. I found it at Advance Auto Parts, and they installed it for free, which was a nice bonus. Total cost came out to about $277 including tax, and it comes with a 4-year warranty.
    Here are the key specs for anyone interested:
    • Group Size: H4
    • 570 CCA / 710 CA
    • 50 Ah capacity
    • 80-minute reserve capacity
    • AGM (Absorbed Glass Mat) design, suitable for hybrid/EV systems
    Only time will tell how it holds up, but I’m optimistic.
    Also sharing the solar charger I’ve been using for reference:
    20W 12V Solar Battery Charger & Maintainer with built-in MPPT controller (waterproof, suitable for cars, RVs, boats, etc.)
    https://a.co/d/06rXxpQc
    20W 12V Solar Powered Battery Charger & Maintainer, Built-in Smart MPPT Charge Controller, Waterproof 20 Watt 12 Volt Solar Panel Trickle Charging Kits for Car Auto Boat RV Marine Trailer
  17. BiomedO1
    4,331
    2,275
    Left Coast
    You don't need that solar charger; if your carrying a jump pack. You've gotten 9 years out of that old battery; so the expectation should be the same with this new one.
    FWIW; If you try plugging that solar panel into your lighter; it's on a relay and disengages the relay when you turn off the car. Those panels only work during the day in a sunny spot; Not under trees, where I mostly try to park.
  18. Mendel Leisk
    42,040
    Maybe depends on the charger? Any decent smart-charger can be left on indefinitely, and if you use it regularly, the only use your jump starter will see is helping others.
