Most fuel efficient 2023 Prius record
Discussion in 'Gen 5 Prius Fuel Economy & Prime EV Range' started by phase, Nov 5, 2023.
  1. Bill Norton
    Bill Norton Senior Member
    2,234
    748
    MONW, Ks.
    2019 Prius
    L Eco
    Nope, not settling.
    Buy an EV and stop pumping that smelly stuff and getting routine oil changes.
    We need to stop BURNING STUFF.
    You can buy Styling Accessories for EV's if you like spending extra money on that sort of thang!(y)
  2. darkstar3274
    darkstar3274 Junior Member
    46
    2022 Prius Prime
    you missed the sarcasm-am saying some people buy things not for payback and that revolve around a business case.
    Bill Norton likes this.
  3. daisy555
    daisy555 Senior Member
    1,729
    716
    CT
    Am I understanding your post correctly? In very good conditions you were getting 62mpg with the 19"stock wheels and about the same in these 17' aerodynamic wheels? So the wheel size really doesn't make much of a difference?
    I just read somewhere (can't find it now) that this Prius can drive in electric mode on the highway somehow. Maybe I misunderstood.
  4. Gokhan
    Gokhan Senior Member
    6,707
    2,658
    Paramount CA
    I am sure you lose a lot of mpg with the 19" wheels—a whopping 10% according to the EPA.
    Ride and everything else is also a lot worse with the 19" wheels, not to mention that the tires are very hard to find. So, it is a no-brainer to get the LE/SE unless there is something you really need in the higher trims.
  5. daisy555
    1,729
    716
    CT
    I would be getting XLE but trying to confirm what this person with the LTD AWD was stating. I know there are many factors determining fuel economy but I'm perplexed by the people who know how to drive a Prius and are only getting 40-45 mpg in mild weather.
    Gokhan likes this.
  6. Gokhan
    6,707
    2,658
    Paramount CA
    He replaced the 19" wheels with some aftermarket 17" wheels; so, it doesn't really compare to the 17" OEM wheels/tires. Regarding mpg info, your best bet is the EPA data. 40–45 mpg for a heavy-footed driver driving an XLE/Limited AWD sounds just about right.
    2024 Prius compare mpg side by side
  7. Bill Norton
    2,234
    748
    MONW, Ks.
    2019 Prius
    L Eco
    Exactly.
    There is unbiased testing, and then there is some dude claiming "blah,blah"....
    And as always, it totally depends on how the car, any car, is driven.
    Lately I've been driving my Gen3 into 20mph headwinds, in 20° temps, at a true 81 mph, (Posted 75mph, I'm rolling at +6, the speedo is +4 high) and I'm OK with the resulting 38-39 MPG.
    If I were putzing around town then I'd be getting "+50 blah, blah...":whistle:
    #47 Bill Norton, Feb 8, 2025
    daisy555 and Gokhan like this.
  8. ingénieur
    ingénieur Junior Member
    27
    Drummondville
    2001 Prius
    I get mostly the same efficiency with both wheel size. It shows a little difference in statistic because of different wheel size (Because they are not showing the same distance for the same destination). I also have a Prius 2001, 2005 and Prius C 2012. Then, i drive and maintain Toyota Hybrid since 2001 (I know how to drive them).
    There is a loss when putting in and getting out energy of battery. Toyota Hybrid strategy is to run ICE only when it is going to be efficient (All energy comes from gasoline). Hybrid battery is mostly for running when ICE is not, to boost power when needed with an efficient ICE and for regenerative braking.
  9. VelvetFoot
    VelvetFoot Senior Member
    1,407
    545
    New York State
    2026 Prius
    My meter says 74.3 mpg on this tank with ~250 miles to go. Crossing my fingers to break 70.
    2023p likes this.
  10. HamiltonPrius
    HamiltonPrius Active Member
    220
    105
    Parts unknown in Virginia
    2026 Prius
    I hadn’t checked my MPG’s since the weather warmed up. My highest in the winter was 58 MPG which I thought was fantastic. So when you said you were getting 68 MPG I thought that was rather high. So I checked my car and I’m getting 66-67 MPG! And that’s on a XLE! You have the LE so I’m guessing 70 isn’t out of the question.
    These are crazy gas mileage readings…..My Gen 4 never got close to this high.
    VelvetFoot likes this.
  11. VelvetFoot
    1,407
    545
    New York State
    2026 Prius
    Plus, it's sporty! Lol.
  12. Michael Hubbard
    Michael Hubbard New Member
    Idaho
    2024 Prius
    Limited AWD-e
    I have a 2024 AWD that just hit 20K miles my life time is 49.8 and it’s been getting better as I put in miles.
    Gokhan likes this.
