Gen 4 EGR cleaning at 360,000 miles
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by jerrymildred, Oct 21, 2022.
  1. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    Some time ago, before I started at this shop, a customer wanted his Gen 4 EGR cleaned at about 140k miles. I didn't get to see it, but I'm told is was super clean.
    This week we got in another Gen 4 for EGR cleaning. This one had about 360,000 miles on it. I will never again grumble about an EGR job on a Gen three. What a PITA that was!!!!
    Anyway, with 360k on the clock, those had to be lots of highway miles, so not a lot of EGR use, but that thing was really clean. Once we finally got it out of there.
    Gen 3 & 4 EGR coolers side by side. Lots more surface area in the Gen 4.
    Inside the Gen 4 cooler after a short blast with an air hose. I wasn't quick enough to get a picture before the air hose treatment, but it was just a little sooty.
    We had to remove several coolant hoses and electrical connectors and unclip the cables in order to pull the inverter out of the way to gain access to the nuts and studs holding the cooler in place. And hold it out of the way with a bungee cord.
    So, I'm thinking that if you have a Gen 4 Prius, you probably don't need to clean the EGR system, but if you choose to do so, brace yourself for lots of work getting it out and in but not much work cleaning it. :D
    And if you do/did clean one, maybe you could share your results? (y)
    #1 jerrymildred, Oct 21, 2022
    buztabuzt, mjoo, Doug McC and 3 others like this.
  2. Mendel Leisk
    42,195
    Wish there was a super-like button. (y)
    @Raytheeagle had similar “fun”, extracting EGR components on his prime.
    Sounds like they sorted out the carbon clogging. A stark difference from gen 3.
    The prodigal son parable comes to mind.
    #2 Mendel Leisk, Oct 22, 2022
    buztabuzt and jerrymildred like this.
  3. ChapmanF
    18,894
    Yes, that would be good. Gen 4 surely has the same built-in emissions monitor that you can ask about your EGR flow score any time you want, same as Gen 3. Starting a similar Gen 4 forum thread with some mileages and flow scores would be a way to get some very useful information, with a lot less trouble than bungeeing the inverter out of the way.
    My guess is that there will be some Gen 4s, maybe with fewer highway miles, that might show worse flow scores than this one did. (For that matter, it would have been nice to know the score for this one!)
    jerrymildred likes this.
  4. jerrymildred
    11,517
    14,164
    Tampa, FL
    Indeed. I came in on it in the middle.
  5. Mendel Leisk
    42,195
    This thread is maybe more interesting to third gen owners: 4th gen Prius, with all the lessons learned from third gen EGR, 360k miles, never had a cleaning, next to no carbon, and no head gasket problems.
    a couple of cold comforts:
    1. the #%*!# 3rd gen EGR components are easier to access (amazingly).
    2. our exhaust heat recovery components aren’t having coolant incontinence issues.
    #5 Mendel Leisk, Oct 23, 2022
  6. ChapmanF
    18,894
    Gen 4 cars have a different EGR system because the auto industry was researching a different EGR chemistry during the years Gen 3 was in design and production, and there are journal papers on the new chemistry, "catalyzed EGR", that were published during that time. Gen 4 uses that newer approach, which hadn't really been commercialized at the time Gen 3 was in design. Taking the gas from after the catalyst changes its chemical make-up and changes its effects on combustion, as the journal papers describe. And the components for catalyzed EGR have to be larger, because the gas from after the catalyst is of lower pressure. Everything must be proportionally larger to get the right flow.
    So there is a good deal more to the change between the Gen 3 and 4 equipment than just "lessons learned from third gen EGR".
    As this thread's in a Gen 4 forum, one hopes it'll stay interesting to Gen 4 owners, who can use it to collect their own data on how a wide sample of their own cars are doing (not all of which will have put on 360,000 miles in a handful of years).
    There won't be anything wrong with us Gen 3 owners peeking in, but we already have our own thread for Gen 3 mileage and EGR flow reporting. We can leave the Gen 4 folks a little space to have their own.
    @jerrymildred, what was the year of this 360,000 mile car?
  7. Mendel Leisk
    42,195
    Yessir...
  8. bisco
    52,695
    most gen 4 owners haven't a clue, unless they owned a defective gen 3
    Mendel Leisk and jerrymildred like this.
  9. jerrymildred
    11,517
    14,164
    Tampa, FL
    I was afraid you'd ask that question. :D I was going to ask several times but kept getting side tracked. I will try my best to remember to ask when I get back to the shop on Tuesday and then try my best to get back here with an answer. I'm curious about that, too.
  10. CR94
    CR94 Senior Member
    2,798
    1,231
    Northwestern S.C.
    3. The 3rd-generation engine coolant pump is less difficult to replace, as I understand.
  11. 2016eco2
    2016eco2 New Member
    Philadelphia pa
    Two Eco
    Hi Jerry thanks for this write up! Its been 10 years and this is the only info i can find on the 4th gen EGR system lol. Im having a stumbling/misfiring issue. It drives fine cold but once its hot. It won't accelerate. It does has a very slight rattle on startup maybe once or twice a week. Im not losing coolant and the plugs look good. I have a replacement EGR system from my last swap i could install but it looks like a pain with the inverter in the way. I feel like if it was a coil or injector, id be getting a code. Any advice on how to proceed would be great.
  12. 2016eco2
    2016eco2 New Member
    Philadelphia pa
    Two Eco
    Im having EGR symptoms on my 4th gen :-( ....it started with occasional rattle on startup but not constant or dramatic.. No codes,coolant is steady and plugs look good so i didnt think much of it. Now im getting stumbling/missfire symptoms once its warmed up, its almost undrivable but Its fine when it cools down. Does this sound like an EGR problem? I wish i had a check engine light to point me in the right dirrect. Any advice? Thanks in advance.
  13. Mendel Leisk
    42,195
    4th gen EGR had significant changes and has not been prone to clog or malfunction.
    Early Gen 4 years have had coolant loss issues due to leaks in the exhaust heat recovery system.
    what’s the miles and how long have you had it?
  14. Brian1954
    Brian1954 Senior Member
    2,595
    1,030
    South Central PA, USA
    2016eco2 created a thread about his car over here https://priuschat.com/index.php?posts/3608514
    It would make sense to keep all the discussions in that thread.
    Merkey and Mendel Leisk like this.
