How badly do serpentine belts age in storage?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mathom, May 5, 2026.
  1. mathom
    mathom Junior Member
    Washington state
    I ordered a serpentine belt almost two years ago (July 2024) from a Toyota dealer. Never got around to installing it. I heard some squealing from the front the other day when starting up, so I plan to remove the belt, put in the new one, and spin/check the pulley and tensioner while I'm at it. The belt is presumably made of EPDM. It's been stored in a climate-stable garage, so nothing too extreme but I don't want it to snap under sudden tension. On the other hand, I can't imagine that two years of indoor storage is harder on a belt than a decade-plus of actual use for the current belt.
    It looks like the new belt was made in April 2024, probably.
    Is it safe to install the new belt? Am I seriously overthinking this?
  2. PrimalPrius
    PrimalPrius Member
    127
    America
    Tons of people around you in traffic are running a 10+ year old belts without a worry in the world.
    April 2024? You”ll be fine.
    Maybe ignore this opinion if you live in zombie-cannibal country. But then you are not traveling in a Prius…
