3RD generation prius instrumental cluster designs
Discussion in 'Gen 3 Prius Main Forum' started by PriusMan2010, May 5, 2026.
  1. PriusMan2010
    PriusMan2010 New Member
    Hello guys, i have always wondered this but never seen anyone mention this before. How come the 2010 Prius and 2011 and above (i assume) both have slightly different instrumental cluster designs? I have a 2010 and it looks basic, where as the newer 3rd gen years have slightly different things like more depth wise colors almost looking 3D like, smoother animations especially in the energy flow chart, and better designs and illustrations. I have attached the hybrid system indicator photo in a 2010 and 2015 prius. Notice the green in the bar is slightly different, along with two small notches in the battery indicator not present in the 2010. I wanted to know why honestly toyota changed it in 2011 models, if anyone else even noticed this, and is it possible to bring this to the 2010 prius? Even features like turning the car off and it displaying fuel cost and trip info is not available in the 2010, yet i’ve seen other 3rd gen’s have it.
  2. ChapmanF
    18,870
    The gen 3 refresh was between model-year 2011 and 2012, which I assume is when that change was made, along with all the other changes that happened then.
  3. ASRDogman
    ASRDogman Senior Member
    7,967
    4,046
    Every manufacturer makes changes and updates, that they don't mention, from year to year.
    Not sure if they are interchangable though.
  4. Tombukt2
    13,742
    2,486
    Any body try n plug up the stuff in the car they want ? Just curious. Usually wen I have apart in looking at plugs n receptacles and some wire colors just because . And if so inclined I will plug it up and watch . Sub harnesses that go to the newer may plun into the original mains harness . Ya never know . Used to be yes alot doing this . After 07 or so . Not so much .
  5. PriusMan2010
    Yeah, It would be cool if I could flash the firmware on those newer Priuses on my 2010. It seems the screen is obviously capable, unless they also changed the screen to be higher refresh rate or something.
  6. PriusMan2010
    What else did they change?
  7. ChapmanF
    18,870
    Hoo boy, a lot. The wheel colors, taillights, front bumper design and lighting locations, leather substitute for the seats, HD Radio receivers, a whole different selection of nav and non-nav, MFD or non-touchscreen headunits, different arrangement of buttons on the steering wheel and HVAC controls ... I'm sure I'm leaving a lot out.
  8. AzusaPrius
    AzusaPrius Senior Member
    2,249
    939
    Not much difference between them at all.
    Only thing really is the oil maint reminder.
    Other than that not much else though.
  9. Mendel Leisk
    42,165
    Just editorial: if you're googling, "instrument cluster" is more succinct. "Instrumental" is a somewhat different word, an adjective I think, throws the meaning off.
    CR94 likes this.
