Losing Coolant
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Saledet, Apr 12, 2026.
  1. Saledet
    Saledet New Member
    Ri
    2019 Prius
    I have a 2019 Prius 90k miles. Lost heat one day and took it to mechanic, I didn't have any coolant. He filled it with coolant and heat came on. About a month later, the same thing happend. Had me take it back a week later and coolant level was low. Did pressure check, checked for codes nothing. Suggested I take it to the dealership. I did, they told me the same thing. Did pressure check, checked everything for leakage, everything is clean. No computer codes. No signs of problems with head gasket. I'm still losing coolant. Adding some in every week. I'm losing the coolant from the engine coolant reservoir.
    Any help would be highly appreciated.
    Maria
  2. RRxing
    RRxing Senior Member
    2,564
    1,842
    NEPA
  3. Saledet
    Saledet New Member
    Ri
    2019 Prius
    Thank you. I'll take this to dealer. Maybe they can figure this out.
    Brian1954 likes this.
  4. BiomedO1
    4,630
    2,427
    Left Coast
    Welcome Maria
    I don't know how all these so called "mechanics" are messing up a coolant pressure test.o_O:cry: This test tells you there's a leak, but NOT where the leak is. Once a leak is verified, clamp-off the exhaust gas heat exchanger hoses. If the leak disappears, that's where it is.
    RRxing is correct; it's a leak into your exhaust gas heat exchanger. I believe Ri is a CARB state and covered under the extended emissions warranty under CARB regulations. Take the car to another Toyota dealership and tell them to TEST for a leak in the exhaust gas heat exchanger. Print out RRxing pdf and show it to them. You need to FIRST get someone to confirm that leak, BEFORE the work can be done under warranty. Once confirmed; go to Toyota corporate, if the local dealership gives you any trouble or ask to escalate to state consumer protection bureau. :cool:
    PS. You should be able to get re-embursed for the dealership diagnostic; that was messed-up, since it is a covered warranty issue. That may be why they claimed that there's no leak????
    Good Luck.....
    #4 BiomedO1, Apr 13, 2026
  5. rjparker
    11,123
    6,979
    Blocking off the flow going into and out of the Exhaust Heat Exchanger is one possible diagnostic test if the leak stops. Another would bypass the Exhaust Heat Exchanger if heater function was needed during the test.
    A coolant pressure test normally would be good enough unless the tech was not waiting long enough or was confused because he did not see coolant leaking anywhere.
    A pressure test really should be done on a cold system which generally means leaving it overnight.
    An Exhaust Heat Exchanger leaks coolant into the exhaust pipe and vaporizes it out the back as steam. No obvious leaks.
    If the dealer were to find the leak in the Exhaust Heat Exchanger but somehow disqualified your car from the free repair, I would have an independent shop bypass that system. There are two ways to do it, one under the car and another under the dash in a relatively labor intensive location. Either way works.
    If it was a head gasket leak the cold start noise caused by misfires would be obvious to anyone and would be the complaint.
    #5 rjparker, Apr 13, 2026
    BiomedO1 likes this.
  6. BiomedO1
    4,630
    2,427
    Left Coast
    I don't have high hopes; since at least two mechanics couldn't find that leak already.:(o_O:sleep:
  7. rjparker
    11,123
    6,979
    The first independent guy is understandable. The second dealer "tech" was probably a junior maintenance guy who gets paid by the job, not by the hour, so he easily could be inexperienced or uninformed as well.
    With better information now, the op should see the Service Manager (not Advisor who often are not mechanics) and find the obvious problem, hopefully before the engine is ruined. Which is exactly what I would tell the Service Manager, find it before my engine is ruined on your watch.
  8. BiomedO1
    4,630
    2,427
    Left Coast
    Sounds like she's on top of it; Since most people won't even pop open their hood. Just point fingers and blame everyone around them.
    It's just sad that people can't or won't do basic diagnostic and testing. I'd cut them some slack, if they didn't charge the hundreds in diagnostic fee - BUT if they billed it - I WOULD EXPECT THE WORK TO BE DONE!!
    There's hope for the next generations....;)
    #8 BiomedO1, Apr 13, 2026
    PHEVisthefuture likes this.
  9. sclevine
    sclevine Active Member
    170
    160
    Northeast Florida
    2024 Prius
    There are so many threads on here about this issue - search heat exchanger. Or even 'losing coolant'. Likely you have same issue, requires new catalytic converter, or an unsanctioned 'bypass'. You can find loads of info by searching the forums.
  10. Mendel Leisk
    42,358
    Whoa Nelly, might be good to verify. It is common, but it's not an certainty. I've a vague recollection it was remedied (they got through, or caught, the bad batch of Exhaust Heat Recovery components), by 2019. Maybe.
  11. BiomedO1
    4,630
    2,427
    Left Coast
    The NHTSA document goes from 2016-2019; I'm assuming any coolant hitting the ground would be caught by those two mechanic that looked at the car. So the EGHE would be the next logical choice; assuming those two other mechanics even looked under the hood. At least one couldn't do a proper coolant leak test. So there's that.
  12. PHEVisthefuture
    PHEVisthefuture Junior Member
    83
    25
    Illinois
    This unfortunately is the norm at most dealerships and even independent shops. Nobody wants to do diagnostics these days it seems, they just want to swap parts all day long and bill the customer for it. I've had so many friends where I told them "GET YOUR CAR OUT OF THAT SHOP NOW" because after thousands of dollars spent, they still had the same issues!
  13. Saledet
    Saledet New Member
    Ri
    2019 Prius
    Hello everyone,
    I took it back to the dealership. Was running late and forgot to take over the documents that you all provided. Got a call 4 hours later letting me know it was the Exhaust Heat Exchanger as everyone said and it was covered by the warranty! That was the best! It's also running great.
    Thank you everyone for your help. So glad I found you!
  14. PHEVisthefuture
    83
    25
    Illinois
    Congrats, glad to hear that it was covered by warranty and you were able to get the issue resolved!
