Quirk in the transmission shifter
Discussion in 'Gen 5 Prius Main Forum' started by HamiltonPrius, Apr 12, 2026.
  1. HamiltonPrius
    HamiltonPrius Active Member
    213
    102
    Parts unknown in Virginia
    2026 Prius
    Has anyone noticed that when you shift the shifter left and forward it makes the car go backwards. Shift left and backwards makes the car go forward……does anyone else other than me think that is backward?
  2. ChapmanF
    18,717
    If you were sitting in a little red wagon, and you reached ahead and grabbed a fence post, pushing forward on the fence post would make the wagon go backward, while pulling the fence post toward you would make your wagon go forward.
  3. BiomedO1
    4,354
    2,282
    Left Coast
    It is, what it is... I always thought reverse polish notation (RPN) was wacky on an HP engineering calculator, but it was called Polish for a reason.:p:cool:o_O Sometimes when I need to work on German or EU equipment, I'll need to reverse the order of things - to understand how it's suppose to work.:censored::rolleyes::sick: I still can't figure out who's brain is messed up - Let me know if you can figure it out.....
  4. PriusCamper
    PriusCamper Senior Member
    13,201
    5,346
    Pacific Northwest, USA
    I know alot drivers I see on the roads these days who I wish would be sitting in a toy wagon pushing and pulling on a fence post far away from roads!
  5. VelvetFoot
    VelvetFoot Senior Member
    1,332
    519
    New York State
    2026 Prius
  6. HamiltonPrius
    213
    102
    2026 Prius
    Just not very intuitive IMO
  7. Trollbait
    12,735
    R is above N, and D is below N, just as it is on other automatic transmission shifters.
    The quirks that could make this seem off is that P is separate button and not above R, and the shifter not staying on the selected gear.
    BiomedO1 likes this.
  8. schja01
    schja01 Senior Member
    1,855
    1,229
    Chicagoland
    2024 Prius
    Limited AWD-e
    It’s the same pattern as a “3 on a tree” shifter
    from times passed but laid flat. Toyota has used this pattern on Prius since at least Gen2.
  9. bisco
    52,538
    perennial question from newbies since at least gen 2 :p
  10. Mendel Leisk
    42,052
    Bite your tongue, RPN was and is great, lol. Say for something like this:
    8x(4+2)
    Which becomes:
    4 ENTER 2 PLUS 8 TIMES
    An app I'm using on my phone, PCalc, free and fully functional, if you don't want some of the more obscure extras:
    Had a venerable HP RPN calculator, the landscape oriented one, very durable. Decided I wanted their "new and improved" version, portrait oriented, mostly plastic, which lasted just outa the warranty perion before it developed a locked, flashing display. It's around here, somewhere...
    And my old one, the durable/venerable one, I gave to my daughter, and it was promptly stolen from her locker at school.
    schja01 likes this.
  11. schja01
    1,855
    1,229
    Chicagoland
    2024 Prius
    Limited AWD-e
    I love my HP Calc and RPN.
  12. BiomedO1
    4,354
    2,282
    Left Coast
    Someone realized what it was; since it's only worth something to an old timer, collector. Everyone uses their phone and apps now. Kids don't even know how to correctly use a slide-rule or abacus anymore. :(:D:LOL::ROFLMAO::whistle: Don't even get me started on making cash change. You don't use it; it turns to mush. I might have that problem, since I can't follow or understand what our current King is trying to say???:whistle:
    Tande, RandyPete and Mendel Leisk like this.
  13. Will B
    Will B Active Member
    447
    412
    Denver
    2023 Prius Prime
    XSE Premium
    For me that shifter configuration seemed OK on my wife's Gen3, but when I went to from Gen1 to Gen5, it suddenly seemed counterintuitive! Go figger. Maybe something to do with being more up/down on the Gen3 vs forward/backward on the gen5?
    Will
  14. Gorgonzola
    Gorgonzola Member
    New Hampshire, USA
    2024 Prius
    LE AWD-e
    I tend to agree that the shifter configuration is counter-intuitive. Mostly because this is my first Prius, and prior to this I was driving a manual transmission — where 1st gear is forward and to the left…so it’s mostly a muscle memory thing for me
    Eddie F likes this.
  15. Eddie F
    Eddie F Junior Member
    27
    Windsor, Canada
    2024 Prius Prime
    SE
    As someone who's other car has 6-speed manual, I also find it counter-intuitive to shift into "Reverse" while switching to 1st gear and "Drive" switching to 2nd gear, but I'm used to it now.
    Gorgonzola likes this.
  16. KCWhitney
    KCWhitney Active Member
    143
    118
    Connecticut
    2025 Prius Plug-in
    And why is it so hard to out it into neutral?
  17. VelvetFoot
    1,332
    519
    New York State
    2026 Prius
    I have no problems. With the car. :)
  18. ChapmanF
    18,717
    They did kind of paint themselves into that corner by laying out the pattern the way they did. Any shift from anything to anything (except D to B) has to go through N on the way, so if they made N instantaneous, you'd really be making two mode changes in rapid succession every time you wanted to shift. So they make neutral only be selected if you hold at N position for a moment.
    If the car is moving at any speed above around 10 km/h, any shift that wouldn't make sense (say, to P, or D to R, or R to D) will be treated as an immediate shift to neutral instead. So, if you're ever (for some reason?) desperate to shift to neutral really fast, and the car is moving, those ways will get there faster than actually having to hold the shifter at N.
    I'm not sure I can think of any reason for being desperate to shift to N really fast....
  19. Trollbait
    12,735
    You'd feel the same with any automatic car
    @ChapmanF beat me to it. The hold requirement also prevents accidental shift N if the knob gets knocked. Wife still managed to do it to me while driving once.
    When the brake interlock fails?
  20. schja01
    1,855
    1,229
    Chicagoland
    2024 Prius
    Limited AWD-e
    I'd like to be able to shift out of neutral to D without having to depress the Brake Pedal.
    Case in point is a car wash that pulls you through. Upon reaching the end I have to depress the Brake Pedal to go from Neutral to Drive.
    I have a Gen5 Hybrid (not Prime) and I don't think my Gen4 Prime worked that way. I "think" I could go from Neutral to Drive without having to press the Brake. I could be wrong.
    I fear getting rear ended by the car following me in the Car Wash. That's all.
