Real-world fuel economy on Gen 5 Prius vs Gen 4
Discussion in 'Gen 5 Prius Fuel Economy & Prime EV Range' started by andentalbania, Jan 25, 2026.
  1. farmecologist
    farmecologist Senior Member
    1,960
    1,801
    Southern MN
    Tires *have* to be mentioned in any discussion of GEN5 MPG.
    The LE model is going to do far better than the others with the chunkier wheels!
    2023p likes this.
  2. VelvetFoot
    VelvetFoot Senior Member
    1,408
    545
    New York State
    2026 Prius
    I got 56.7 mpg on my LE, actual, US, last tank with snow tires.
    I'm hoping to get more after they get changed out.
    Hopefully even more when I get the oil changed in 3000 miles to "certified" 0W8, lol.
    2023p likes this.
  3. Paul Gregory
    Paul Gregory Senior Member
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    What did you actually mean to say?
  4. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I was a little disappointed yesterday, to discover that my VW Golf was getting better mileage than my Gen 5 Prius.
  5. VelvetFoot
    1,408
    545
    New York State
    2026 Prius
    Is it a TDI? :)
  6. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    exactly
    VelvetFoot likes this.
  7. VelvetFoot
    1,408
    545
    New York State
    2026 Prius
    I loved my yellow 2000 TDI Beetle. Put 225k miles on it. Still looked and ran great when I sold it.
  8. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    It's encouraging to know that both Toyota and Volkswagen have been the top auto producers in the world.
    I don't think it's a coincidence that they were both committed to quality and longevity.
  9. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    Unfortunately, the Prius Atkinson cycle engine is unable to employ a stratified ignition profile, which allows a lean mixture to detonate without damaging the engine. This is accomplished in the cylinder when direct fuel injection creates a small zone of rich mixture, which acts to cushion the shock of detonation of the leaner mixture.
    I don't know enough about engine mechanics to know if it would be impossible, or whether stratified ignition has not yet been developed in the Atkinson cycle engine. I suspect it would have been done by Toyota engineers, were it possible.
  10. mva
    mva Active Member
    177
    105
    B.C. Canada
    2024 Prius Prime
    SE
    I’m guessing those are imperial gallons which are quite a bit bigger than US gallons.
  11. DOHCtor
    DOHCtor Active Member
    170
    103
    Levis (Quebec city's south shore)
    2024 Prius Prime
    SE
    Hmmm having had both a 2021 and a 2024 and now a 2025.
    -Strictly from a gas hybrid point of view, like when the battery is depleted, my 2021 was always easier on gas. Don't quite remember the exact numbers but more or less 0.5l/100km if i remember right.
    -However, in the real world, the fact that i can do more or less twice the milleage on battery alone make the 5th gen more economical for me. I do about 120km daily..
    My POV, depending on how many miles/km you do daily, both can be more economical then the other. The 4th gen being the more economical choice if you do tons and tons of milleage daily and the 5th gen being more economical to run if you do enough milleage so the bigger battery give enough range to offset the fact that the bigger engine is a bit thirstier but not so much for said bigger, thirstier engine to take more fuel than what the 2ZR would have took.. Does it makes sense? I was literally translating my thoughts from french to english...
  12. Gokhan
    Gokhan Senior Member
    6,714
    2,672
    Paramount CA
    I still get over 65 mpg in actual average fuel economy (after accounting for battery use) in my 2021 Prius Prime Limited at 50,000 miles. It is probably the most fuel-efficient Prius ever made, thanks to its low ground clearance (lower than that of the Gen 4 Prius Eco HEV and way lower than that of the Gen 5).
  13. NickBreston
    NickBreston New Member
    Framingham, MA, USA
    From what I’ve seen, Gen 5 seems to keep Gen 4-level efficiency but adds more usable power and better highway stability. It doesn’t feel like a big MPG jump, but more like Toyota finally balanced performance + economy instead of chasing numbers.
  14. notspam3
    notspam3 Member
    138
    74
    Toronto
    2024 Prius Prime
    XSE Premium
    Gen5 PHEV all time average 200 miles/USG or 1.1L/100km over past 12 months
    Gen3 HEV all time average 41 miles/USG or 5.7L/100km over 300K+ kms
  15. VelvetFoot
    1,408
    545
    New York State
    2026 Prius
    68 mpg last tank. I do try though.
    2023p likes this.
  16. Eddie F
    Eddie F Junior Member
    28
    Windsor, Canada
    2024 Prius Prime
    SE
    What I'd love to be able to buy here is what they have in Europe - 6 speed manual Corollas HEV... Of course the best option would be 6-speed manual PHEV... One can only dream.
  17. rjparker
    11,099
    6,966
    It probably was a dream. An essential part of Toyota hybrids is their ecvt transmission with two electric motors, planetary gears and a differential. No clutches.
    Some earlier models (like non-hybrid Yaris or Auris) might be mistaken for hybrids, but in Europe, the 1.8L and 2.0L hybrid systems are automatic (ecvt) only.
    There are some Toyota hybrids with simulated "gear" changes with the shifter or paddles. But they remain ecvts.
  18. Eddie F
    28
    Windsor, Canada
    2024 Prius Prime
    SE
    I haven't driven one, but I have seen HEV decal and stick shifts on multiple Aurises (they look like Scion iM 2016, Toyota Corolla hatchback 2017 sold in NA)
  19. Trollbait
    12,828
    The AI was confused. There is no manual transmission Toyota hybrids. Power split hybrid systems won't work with them. The Hybrid Max models are a parallel system mated to a traditional automatic. The Auris only ever had the power split one, and 3rd gen Auris is the Corolla. In Europe, some markets got a conventional engine option in some markets that would have a manual option. I don't think even Toyota's mild hybrid diesel can be had with a manual. Some have called basic start-stop a hybrid.
    Auris 2010: Introduction
    The New Toyota Auris - Toyota Media Site
    Toyota Auris - Wikipedia
    Someone at work had an Audi Ridgeline, and I spotted a new LHD Holden once on my commute.
    Adding and swapping decals is a simple thing to do.
    2023p and Eddie F like this.
  20. Mendel Leisk
    42,345
