Pump Noise?
Discussion in 'Gen 3 Prius Technical Discussion' started by Dan0, May 6, 2026 at 9:53 PM.
Tags:
  1. Dan0
    Dan0 Junior Member
    24
    TN
    Our 2010 Prius has always made this sound but it seems to be more frequent lately.
    It will make this sound when I first get in the car but it's doing it about every 18 seconds driving around town now.
    It's a whirring sound, starts out higher pitch and then winds down.
    Anyone know what it is and if I should be concerned?
    Thanks
  2. ChapmanF
    18,699
    It's the pump that repressurizes the brake fluid when the pressure drops as you use the brakes (or, in this case, when the pressure keeps dropping on its own because of internal leaks developing, usually inside the brake actuator). Internal leaks don't result in any visible brake fluid outside the system; it just leaks back to the reservoir, and the pump has to pump it up again.
    The pitch drops as it pumps because it is working harder as it builds toward the target pressure.
    Brian1954 likes this.
