Shudder at initial acceleration
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Nicholle, May 6, 2026.
  1. Nicholle
    Nicholle New Member
    Seven Lakes, NC 27376
    Hi all!
    I have looked through here and haven't quite found a post that is like my issue so I'm hoping someone has some insight. My prius has developed this shudder when I press on the gas pedal. It was worse when I first started the vehicle after it had sat for about 3 hours. The gas engine had kicked on and I put the car in reverse, when I pressed the gas there was a strong shudder. I waited a second or so and tried reversing again, no shudder. When I came to my first stop and the engine cut off, the car shook again pretty aggressively. After this, it seemed to only have a less intense shudder when I first hit the gas pedal. The best way I can describe the feeling is similar to a torque converter failing on a gas vehicle, but it occurs when I first accelerate vs. at ~ 45mph.
    I of course ran to google and all I can find is spark plug and/or ignition coils potentially being the issue. I have spark plugs on the way already and were going to change them this weekend, but wondering if it could potentially be something else more serious. Thanks!
  2. JC91006
    JC91006 Senior Member
    16,933
    8,643
    You can run a live test and see if there is a cylinder that's misfiring. Techstream or similar software can do that. The spark plugs are rated for about 120k miles so if yours are older than that, then you should change them. But I feel your problem would be bad fuel injectors. If the spark plugs or coils would be an issue, it would not improve as the car warms up.
    Nicholle likes this.
  3. saneesh8
    saneesh8 Member
    235
    55
    Allen, TX
    How many miles? Also the engine mounts are in good shape ? You can try cleaning the fuel injectors.
  4. Tombukt2
    13,800
    2,503
    When this is occurring the engine is bucking or making that torque converter noise. Do you see chk engine light or trac light flicker ??
    Tim Gravit likes this.
  5. Nicholle
    Nicholle New Member
    Thanks! Fuel injectors was my next guess but I wanted to try the spark plugs first since they are on the way. The car has 179K miles and fairly new to me so I am not sure they were ever changed. There's no info on the carfax about it, so I'm just assuming not.
    Tombukt2 likes this.
  6. Tombukt2
    13,800
    2,503
    Sounds to me like you're going to have misfire codes pretty easy to check orieleys etc . The head gasket issue and all that nonsense is pretty rare on a generation 2 until we'll abused
    saneesh8 likes this.
  7. Nicholle
    Nicholle New Member
    There is no noise from what I can hear. No dash lights and I ran my OBD2 scanner and no codes!
    Sorry I should've included miles - 179K! Engine mounts looked good to me, but I'm no expert lol. I can have someone a little more knowledgeable check on that for me though.
    #7 Nicholle, May 7, 2026
  8. Tombukt2
    13,800
    2,503
    The next thing to do is take your four spark plugs out . Take a poly tube about 15 inches long maybe 5/16. Stick hose in spark hole watch it go in the plug hole not just the well. Now sniff the tube gently . Smell.coolant? Check the other three cylinders if you have an inkling of coolant odor . That's yer issue . . Or you rent a inspection cam
  9. Nicholle
    Nicholle New Member
    Will do! Thank you!
  10. pasadena_commut
    pasadena_commut Senior Member
    3,002
    932
    Southern California
    Where are the spark plugs from? Amazon is full of counterfeits. Plugs from a dealer or RockAuto should be the real deal. This applies to all OEM parts.
    This matters because often the counterfeit will make the car run worse than the old OEM part which it replaced.
  11. Tombukt2
    13,800
    2,503
    The bad plugs come apart in engine . Soon as bad running starts get home whip em out and look well with a loupe .take plug in hand by the top and shake like you drawing down a thermometer for you're kid before digital. Hear the rattle yep .
  12. Nicholle
    Nicholle New Member
    I ordered them off Amazon per someone’s recommendation but I just placed an order for pick up at oreilly’s after reading your comment! Thanks!!
    Thanks so much for all your help!! I’ll be replacing them today so I’m hoping that is my issue. But I know for next time to check asap. I really appreciate your help.
    #12 Nicholle, May 9, 2026
  13. Nicholle
    Nicholle New Member
    Update: I changed the spark plugs and the shudder is gone! I’m still planning to take it to a mechanic just to look over everything, but I’m hopeful this was the cause and is fixed. Thank you everyone for the help!!
  14. Tombukt2
    13,800
    2,503
    Yes the plugs are probably fixed and starting to come apart hopefully. You caught it and everything you took out looks like a spark plug nothing's missing
  15. Tombukt2
    13,800
    2,503
    I wouldn't bark up the injector tree just yet many people have done so with lesser mileage with no satisfaction . Apparently the Toyota fuel injectors are very well made and it's not uncommon for them to go three or $400,000 miles apparently very easily I have never replaced factory injectors with good results. In other words the problem has never been fuel injectors in my 47 years so far .
