Growling sound while driving
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by BAT PRIUS, May 5, 2026 at 8:17 PM.
  1. BAT PRIUS
    BAT PRIUS New Member
    Tuesday
    Hoquiam
    My car has started making a growling sound while driving. It gets louder over 60 mph and after 50+ miles at 60+mph, the growling is very noticeable at all speeds, even in town traffic. I jacked the car up and checked all wheel bearings, nice and tight and no growling when I spin them. Put the car in gear and no growling sound when spinning in the air (car was not warmed up when I did this). I suspect the differential. I checked transmission fluid and it is full, but ugly. Will bad fluid cause a growl? Also, I don't have Toyota WS fluid but was told Valvoline Maxlife Multi vehicle fluid is acceptable to use. Should I use it? I have it here right now. Also, the transmission and differential use the SAME fluid, or are they somehow separated inside the trans axle?
  2. saneesh8
    saneesh8 Member
    222
    Allen, TX
    Change the transmission fluid with Toyota Original .. you can buy from local dealer or shop online..
    The growling with wheel bearing usually changes "tone" with slight change in gas.
    Tires, are they good? Tires, especially winter tires can make noise
  3. ChapmanF
    18,701
    There's no separation inside the case; it's all the same fluid.
    BAT PRIUS likes this.
  4. BiomedO1
    4,333
    2,276
    Left Coast
    If there's no sound in the air with the car in gear; WHY do you think it's the transmission/transaxle???????????? Isn't it spinning when you had the car in gear in the air???????
    I've had bad wheel bearings that didn't present themselves until you loosened the half-shaft and what about the rear axles. You running that Prius on only two wheels??????
    If you loosen that half-shaft nut and push it back 1/4 inch; your wheel will wobble if that bearing is gone. The hub will also heat up, due to all the friction. Don't wait too long cause things will start wielding together.
    #4 BiomedO1, May 6, 2026 at 9:29 AM
  5. Tombukt2
    13,578
    2,449
    Wheel bearings usually present noise loaded with weight . In air almost nothing . Now take stehscope whilst spinning carefully listen to bearing housing rt at axle penetration . You hear the balls moving round scrape scrape etc . Pull it out of ears ya hear nada .
  6. 6079smithw
    6079smithw Junior Member
    N. Nevada
    I'm with Mr. saneesh8 here; check your tires first. I had a 2001 Saturn that I would have sworn had a failing wheel bearing RH side; classic growling sound that changed pitch with speed. No play or noise in the bearing when jacked up, same as OP here. My neighbor suggested I swap the front tires L-R and drive the car... Bingo, noise switched to the left side. Replaced that tire, no more noise. Turns out that certain tires will do that from wear. Saved me a bunch of grief not to mention $$. You might give that a shot; nothing to lose except a few excess calories lol. Good luck!
    BAT PRIUS and saneesh8 like this.
  7. BAT PRIUS
    Tuesday
    Hoquiam
    My tires are in good shape, I bought them long before my car started making this noise. They are the same brand and tread of tires as the previous tires they replaced. Tires are at 75-80% with perfect tread wear.
  8. Leadfoot J. McCoalroller
    8,168
    7,673
    Pennsylvania
    2018 Prius c
  9. BAT PRIUS
    Tuesday
    Hoquiam
    Are you talking about the spindle nut that can be seen as soon as the hub cap is removed?
    My initial gut diagnosis was the right front wheel bearing because the most vibration as at the passengers feet. Since my transaxle was full when I checked it, it pretty certain it is a wheel bearing that I missed the first time I checked.
    The wheel bearings "seemed" fine the first time I checked them...but I am going to do an in depth inspection starting with the front right corner of the car where the noise seems the loudest. I am used to my old Ford's and Chevies that when you check for a bad wheel bearing, they are super easy to immediately tell which one is the bad one
    #9 BAT PRIUS, May 6, 2026 at 5:45 PM
  10. ChapmanF
    18,701
    You can see from my old how to tell which wheel bearing? thread that sometimes it's really hard. All the different rules of thumb people usually suggest were falling flat, and I had to go get my hands on a ChassisEar before I could actually be sure which bearing it was.
    On the bright side, once the ChassisEar was hooked up, picking out the bad bearing took like three seconds.
