Featured Motor-oil shortage on the horizon
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Gokhan, May 3, 2026.
  1. El Dobro
    El Dobro A Member
    7,098
    3,275
    It's not mentioned, but it also affected GM's OEM filters.
  2. xw20_driver
    xw20_driver Member
    115
    58
    PNW
    Pennzoil Ultra Platinum is made from GTL. I grabbed two 5 QT jugs back in late March when this news broke. Walmart had these priced at $26.48 per jug and there is a $30 rebate.
    $23 for 10 quarts of high quality full synthetic 5w30 or $11.50 per jug. That's cheaper than store branded oil.
    Gokhan, hill and bisco like this.
  3. hill
    8,974
    Being strategic always beats the alternative
  4. Gokhan
    Gokhan Senior Member
    6,611
    2,627
    Paramount CA
    Just to reiterate, GTL base oils are second only to those made from Group IV (PAO) and Group V (POE, AN, etc.) base stocks in base-oil quality. The Shell Pearl GTL facility was one of a kind in terms of capacity, and it’s a pity it will be decommissioned for a while.
    In the curve below, for a given CCS (cold-cranking start) viscosity, the lower the Noack volatility, the higher the base-oil quality, resulting in a higher viscosity index, a lower oxidation rate, and so on. As you see, natural-gas-based GTL is roughly equal to Group IV (PAO) in base-oil quality, and it far surpasses petroleum-based Group III base oils. As you can also see in the figure, it is even hard to meet the GM dexos1 Gen 2 spec—the horizontal line that indicates a 13% maximum Noack volatility, which has actually been even further reduced to 12.5% in GM dexos1 Gen 3—without using some percentage of GTL base stock in the base-oil blend. So, the problem is not limited to European specs, such as the Mercedes–Benz (MB) specs, which specify a maximum Noack volatility as low as 11%.
    #24 Gokhan, May 10, 2026 at 6:09 PM
